Black Lug Nuts for Wildtrak?
JBTHERAT
Jon
Houston
‘24 Highlander, ‘15 Taurus, ‘18 Edge
Do the the Wildtrak wheels have the conical/cone seat? I want to switch the lug nuts to black and I’m trying to avoid the $160 that Ford sells on their accessory website. I’m also adamant about having the correct diameter so as not to show the bare silver ring void that the stock lug nuts cover. Many of the aftermarket lugs are narrower than the oem’s.
I’m having trouble finding lug nuts that confirm the same diameter that won’t leave the silver ring.
Can anyone confirm an identical size black lug nut product? Not one that is close and kind of looks good.
What say you?
Glenjafett
Atlanta
2023 Bronco
I used the Mcgards... and a Black sharpie paint pen. It's a tiny area that you would never see if you use the paint pen first. No matter how close the match is. It's less than an eighth of an inch you're covering.
Dialtone
Twilight Zone
Bronco Big Bend Mid
I'll 2nd the McGards. A nice feature is they sell the Bronco locking nuts in a 5 pack. No ring. The locking nuts were p/n 24526 M12x1.5 conical seat. The regular nuts come in a 4 pack so you'll need 6 packs plus one. I bought 7 packs so I'd have a few spares and the spare tire.
Ford Bronco Black Lug Nuts for Wildtrak? Small Rally Flaps
WheresMyBronco
Los Angeles
2023 Badlands
Definitely check McGards, I think it'll tell you what fits on their website. Plus, I believe it's the same lug nuts that you see on that Ford listing
SeptuagenarianSasquatch
Randall
Consider these conical wheel locks. Kind of pricey, but they seem superior to others. I got 'em on my Badlands Sasquatch. Available for $137 at advancedwheellocks.com. Each set is unique. (And as a writer, when I say 'unique,' I mean that literally.)
Ford Bronco Black Lug Nuts for Wildtrak? 1711255121438-31
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Can someone explain to me the difference between these two sets of McGard black lug nuts? When I enter in my vehicle info (2021 Ford Bronco Badlands - Sasquatch package with OEM wheels), it gives both these options:
https://mcgard.com/product/black-bu...del=Bronco&vehicle_category=24&vehicle_text=1
https://mcgard.com/product/black-co...del=Bronco&vehicle_category=24&vehicle_text=1
It looks like just the hex size is different, so what impact does this have and which would be right for me? I’m assuming 3/4” but wanted to confirm. Looks like the length is slightly different too.
And these should be the set of wheel locks that I need?
https://mcgard.com/product/black-wheel-lock-set-m12-x-1-5-thread-size-set-of-5-locks-and-1-key/
Thanks in advance!
RBJRBJ
Bruce
2023 Bronco
Thanks in advance!
For the first two links you posted, the difference is in Hex size. One version displays a Hex size of 3/4” while the other link displays a Hex size of 13/16” a tad larger than the 3/4” Hex size.
The last link you posted displays the 3/4” locking lug nuts with the wheel lock key.
RBJRBJ
604Bronco
British Columbia
www.bronco6g.com
RBJRBJ
Thank you - You mentioned basically everything I noted in my post though, lol.
I was wondering if I need the 3/4" or 13/16" one for my Bronco... What is the OEM spec ones?
RBJRBJ
Bruce
2023 Bronco
RBJRBJ
Bruce
2023 Bronco
Extreme Terrain states for their black lights: “Black Factory Style 3/4-Inch M12x1. 5 Lug Nuts in Set of 24 fits all 2021-2024 Ford Bronco, Excluding Raptor Models.”
https://www.extremeterrain.com/bron...nch-m12x15-lug-nuts-set-of-24-80k645blk.html#
Read this article FIRST:
https://www.bonoss.com/socket-ford-bronco-lug-nut-chz401.html
NOTE:
“The most common lug nut socket size of a 2021-2024 Ford Bronco lug nut is 3/4” (19mm). But there are a few Bronco wheel nuts that would need a 13/16” lug socket to fit.”
RBJRBJ
Bruce
2023 Bronco
604Bronco
British Columbia
www.bronco6g.com
TheShark
McGards all the way!
Glenjafett
Atlanta
2023 Bronco
You need the 3/4 or 19mm. They are the same. The 13/16 or 21mm wouldn't fit your factory lug wrench.
Here is the Sharpie pro I used. Its been on for months no issues. It's hard to see, but it completely blacks out the outline.
Ford Bronco Black Lug Nuts for Wildtrak? 20240324_185138
Ford Bronco Black Lug Nuts for Wildtrak? 20240324_185225
Ford Bronco Black Lug Nuts for Wildtrak? 20240324_185555
