Bimini Top Question
BroncoKong Jr.
Andrew
I went with @JTopsUSA as well. But I had emailed them way back in August asking if they were going to make Bronco shades. The answer was yes (and due out in the Spring) so I waited!
cpsocal
I'm not a fan of either option, Bestop has a cross bar, that's a no from me, and Gearshade has those ugly black triangles on the front corners, also a no from me. Hoping for something that's simply just mesh with a rim of some sort. As little visual opstruction as possible when driving open. Beside, GS calls these "pockets", I guess they have zippers? I can't think of a thing I'd ever put there.
Got some more time before the real summer heat hits here. Get with it after market! ;-)
GearShade makes a version of their mesh top without those triangle pockets. The pics here show the pockets but I did confirm they will be all mesh no corners. Just ordered one myself.
https://www.gearshade.com/product/4-door-bronco-mesh-top-no-pockets/
Ftchmup
WI
23 Bronco, 20 F-250 Tremor
leby065
Chicago
Infiniti FX35
Take a look at JTops!
broncosunshades.com
evening! Just took a look at your site. I’m a bit confused how I would reach the latch to secure or release my soft top. It looks like the gear shade goes right to the edge and that nylon border flipped up won’t leave enough room to put the top back down on my own.
does that make sense?
thanks!
JTopsUSA
www.broncosunshades.com
Ram 1500 diesel,
thanks!
This is a great question!
The front nylon strip flips back and the soft top hardware has access to the locking flanges. It works perfectly! This a JTopsUSA patented feature we have been using on our Jeep products for years.
When you fold the hardtop back it flips back forward and closes the gap. There are 4 neodymium n48 grade commercial magnets that hold it tightly closed so there is no gap, no wind or sun coming through.
I hope this helped answer your question.
Mike Matras
Owner
JTopsUSA
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
I like it and I do think the middle bar reduces waviness/flapping while driving; how could it not?
The only flapping sounds I get on the highway, are from the four tightening straps at the rear of the Bronco. I could tuck the straps in if I wanted but I actually think they look cool hanging down plus it allows me to hang a flag back there.
need a pic of your flag set up. Sounds promising.
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
Working on it. We take things slow and test, test, test. It must be right or we will not put our name on it! we are on prototype number 5 and still working.
Don't know if there is a "list" to get on for a 2-door in black mesh, but I would like to be on any such pre-order list. Thanks.
JTopsUSA
Ram 1500 diesel,
Best thing is to order free color samples from our website and get on the mailing list. Also we will announce when we start preorders on this forum and Facebook.
I’m hoping we are ready in a couple of weeks.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
How’s the Bestop? I feel like the middle rob should add some resistance to flapping?
The middle rod helps with flop but chatters horribly at 45mph plus. I’m gonna have to put rtv in the rod then assemble if the rod had rubber instead of hard plastic it wouldn’t make the noise.
NM_21Bronco
New Mexico
2019 Explorer
Are you guys looking at making shades that work with the factory hardtop?
JTopsUSA
Ram 1500 diesel,
Yes we are working on the final version next week! The design team is getting together ti finalize the design!
This is a pic of a prototype of the soft top version.
Ford Bronco Bimini Top Question JTops Ford Bronco bimini sun shad
The Black Key
Newport News, Virginia
2022 Ford Bronco
My Bimini top is super tight, looks good and no sag. But, there is some"chatter" from the two front clips. To solve that , I've put a very small piece of tape (duct) on the Bronco latch receivers to keep the plastic clips from direct contact with the two receivers from rattling at highway speeds. Below 50mph, top is very quite.
I did the same thing today. My passenger side clip was “chattering.” I cut 2 pieces of Gorilla tape to size and put them on the actual clip. Fixed the issue.
charlieecho
Charlie
2018 F150 ecoboost
so after 3 weeks those straps on the back have basically worn out. Either broke or have stretched out to the point the plastic won’t clip anymore. Have you experienced this ?
RCVBAF
Brett
Caddo Mills TX
2023 Ford F-150 Heritage, Ford Ranger FX4, & 2025 Bronco
So I stopped at the Ford Dealer that I bought my Bronco from. I am interested in getting a Bimini Top <— I may of spelled that wrong. Anyway the top that was installed on another bronco was super loose and floppy. I would think with the top down that would make a bunch of noise and flop around. Are they installed tight? Are they noisy? What do you think? Should i get fords? Or Gearshade?
I got a JTops. No flop at any speed.
