Best replacement for SAS shocks and struts
Tomskullz
Tom
Bullville, New York
2022 Ford Bronco Badlands Sasquatch 2.7
Hello I have a Bronco Badlands SAS with a BDS lift kit just noticed the driver side rear shock leaking from reservoir. Looking to replace struts and shocks, any recommendations in replacing them.
thank you !
MNBigfoot
MN
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
The question is very subjective. Do you have a budget? What do you use the bronco for? What are your goals with it? Is it for looks or for off-roading? What kind of off-roading do you do? What kind of experience do you have? Are you just looking for the most similar shock setup to replace and forget? In that case get the Ford performance set which is also the Bilstein 6112’s. Or look for a pair of used Fox Hoss 3.0’s.
Snacktime and a few others have compiled some great threads on suspension here that go over a bunch of options easily found through the search bar.
https://www.bronco6g.com/forum/threads/2025-suspension-recommendations-by-snacktime.108733/
A few others of us including myself have gone into more details on specific, more expensive setups like Bilstein, Accutune stuff and more. It’s all very subjective though so more info would be nice.
