Best Rear License Plate Relocation Bracket?
Slick85
Richard
Austin, TX
So I installed the 4WP rear bumper and love it... but I hate how the license plate is now mounted up by the tire. I am not sure if the 4WP one can be relocated to the tailgate, but I would like to have it out of the way. The two I see that look good are the DV8 and Turn Offroad brackets, which one would anyone recommend?
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
I'm interested as well. Looking for a bumper for our 4 door. I like the ADD Rockfighter rear bumper on our 2 door as it keeps the plate on the bumper, but I've have constant false alerts with the middle two sensors. Most other high clearance bumper options require plate relocation.
jsoa
Jose
Delaware
2024 Bronco 4dr
I have the TOR and like it, I choose it because the way it mounts.
Others that I've seen either use the Ford emblem as an attachment point or they use tire carrier mount.
I also have the TOR tire carrier which made an relocation using the tire carrier as an attachment point unusable.
Only complaint I have is the included light is crappy and should be more powerful.
jsoa
Jose
Delaware
2024 Bronco 4dr
for reference
Ford Bronco Best Rear License Plate Relocation Bracket? PXL_20251130_231115580
Ford Bronco Best Rear License Plate Relocation Bracket? PXL_20251130_214111192~2
ThunderFlash
Doug
Washington
Ah, I see how that attaches. I thought were using the spare tire mount fasteners. Thanks for that @jsoa. For the light, did you have run wires across the truck bumper the back across in the tailgate?
jsoa
Jose
Delaware
2024 Bronco 4dr
Yea, the picture doesn't show it as that picture was taken before I installed the light, but it routes through that notch you see, through the tailgate, to the trunk tray where your tire jack is, through a rubber grommet, then over to where the original light wires are. After that it requires you to cut off the original light and splice in the wires.
I added a quick disconnect near the bumper in the event I need to remove the bumper, and also added some foam padded to the bracket that rests on the underside of the tailgate.
ThunderFlash
Doug
Washington
OK. I was considering one of the DV8 bumpers with a LP mount on the bumper, but they stick out beyond the body. Pretty sure I'd mangle that on a tree as the Bronco is a tight squeeze on many of the trails here.
jsoa
Jose
Delaware
2024 Bronco 4dr
the bumpers I got are pretty tight, but they do stick out a little beyond the body, less so then the capable bumper. These also came with a LP mount that hooks up to the spare tire, but wasn't a fan.
ThunderFlash
Doug
Washington
I just saw this mount today at my local 4X4 shop (Billy Bob's Off-road). It's from Kentrol (made in China if that's a deal breaker) but it seems very sturdy. It clamps to a recovery point lug. You'd have to wire in a LP light, but it has holes for attaching a light. That might provide some flexibility.
Ford Bronco Best Rear License Plate Relocation Bracket? PXL_20251229_232114027
Ford Bronco Best Rear License Plate Relocation Bracket? PXL_20251229_232101827
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
for reference
How’d you run the wire? Through the gasket near the spare? I’m not a fan of how they run it in their video. It’s exposed under the tailgate. Come spring I’m redoing it.
jsoa
Jose
Delaware
2024 Bronco 4dr
mine is like their video yea
