Best on-board air compressor mount
cr117
PNW
Bronco, EV6
I was scrubbing the video but wasn't sure if he said the tires on the rigs are exactly the same size?
Yeah I did the same. I know the 2nd truck (not his) had 38" tires. But Im not sure what size HIS tires were. If he has 33" tires for example that's a big difference.
In the comments he confirmed both rigs have the exact same tires.
Ford Bronco Best on-board air compressor mount Screenshot 2024-02-28 at 12.55.15 PM
cr117
PNW
Bronco, EV6
MORRFlate TenSix: 1 minute, 40 seconds
ARB Twin: 1 minute, 40 seconds
How was your ARB set up, is the hose coupler mounted directly to the compressor itself?
I'm wondering if these other tests online are comparing the MORRFlate with an integrated ARB system that's using smaller diameter hoses/fittings. That would explain at least some of the variation in inflate time.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We have the ARB hose going right to the compressor. Then i'm using a tire inflator (not an ARB one, some one I got on amazon years ago).
I also did the same thing with the MORRFlate.
Originally I connected my tire inflator directly to the MORRFlate Hose and got the same time frame then I said "well maybe we should use the ARB hose for both, to keep the hose diameter the same" but got the same results.
Tomorrow we'll try doing all 4 at once with each setup.
l88m22vette
IL
Please sir may I have locking diffs?
I love the AAL tailgate mount, the ARB single works perfectly with their harness and an AUX switch. I used the AUX to power the compressor switch on the harness, which is mounted next to the air chuck, so it doesn't power on if it gets bumped by cargo.
Ford Bronco Best on-board air compressor mount AAL ARB air comp mount insid
cr117
PNW
Bronco, EV6
Yep, the hose/fitting diameter has got to be making a difference. The test you ran is probably the most accurate when comparing raw output of both systems. It seems like most of the ARB integrated air systems use smaller diameter tubing and couplers (in comparison with the coupler mounted directly to the compressor, see comparison below), which probably significantly restrict airflow.
Ford Bronco Best on-board air compressor mount Screenshot 2024-02-28 at 4.15.25 PM
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well those would not matter since I'm using an ARB hose for both tests. One connected directly to the screw in coupler and the other connected to MORRFlates built-in hose coupler, which uses the same style connector (universal for air devices)
cr117
PNW
Bronco, EV6
Right, that’s why your test results were the same between both products, which is probably accurate. What I’m saying is tests like the one in that video I linked earlier probably wasn’t the fairest comparison since the ARB onboard system used utilize smaller diameter fittings.
mattyp44
2023 Bronco
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I'm here researching a solution that works for my rig and needs. I've been curious about this one, the biggest downside I see is having to unload anything in your trunk space to access the compressor. Am I interpreting this design correctly?
Yes that replaces the storage bin in your truck. You retain SOME storage but not as much as before.
You can go for our onboard engine mounted compressor kit. It's tucked out of the way and easy to access. One of the most popular and easiest to install on the market. In fact, we utilize existing mounting points and our hardware kit only contains TWO bolts and nuts to use! Real simple
https://www.4x4truckleds.com/kr-off-road-air-compressor-engine-bay-kit-for-2021-ford-bronco/
Ford Bronco Best on-board air compressor mount 1736380503976-x6
agir
Agnes
Sacramento
The engine bay will get pretty dirty if you wheel in dusty conditions. That's what I have using the KR Off-Road bracket. It does generally work fine though, but you can tell it does absorb quite a lot of heat from the engine. Personally I'm fine with it out of sight like that.
There is one solution that mounts behind the spare tire, that looks cool, but keep in mind you'd be running quite a long and thick wire from the engine bay to the swing gate. Another solution just released is from American Adventure lab which hides an ARB single INSIDE the swing gate. Now that's cool.
I can't speak for the performance of the other solutions, just that I'm happy with mine. I loathe running wiring so it's been ideal for me.
So far from what I've seen the American Adventure lab's solution is the best. I'll be going with that. I have most ARB parts already, just need the harness and the bracket, etc. Thank you for posting this!
oli222
Oliver
Switzerland
Bronco Badlands 4-door 2023
I ordered the Barnes bracket for ARB twin under hood. Was like $80. No way I’m spending $250+ for a piece of bent and painted sheet metal.
Hej
do you have installed it already - and you happy with it?
Thanks
Oliver
4x4TruckLEDs.com
Adam
Lindenhurst, NY
oli222
Oliver
Switzerland
Keep in mind ours are Made here in the USA out of Stainless Steel and carry a lifetime warranty. So they won't rust on you unlike regular cheaper steal. Our kit also fits the single and twin air compressors both the original and the new brushless
Hi Adam,
thanks for your input on quality.
I was on your webpage and asked for a quote (KR mount plus ARB Twin Air & accessories)
I'm located in Switzerland - so curious on your offer including shipping.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Hi Adam,
Sorry we do not ship to Switzerland
