Best Backup Plan for a Lost Key
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
are they really?
Ive opened mine up to change the battery... the housing definitely isnt waterproof, and the circuitry doesnt look sealed.
then maybe if you go camping you might need a ziplock bag. or a little pelican case to protect your key...
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Guess I’m going to show my age, but are y’all saying one can no longer start a vehicle with the old fashioned tried and true mechanical metal key?
Now get off my lawn.
dgorsett
colorado
F250, Mustang, Explorer
Ha Ha, remines me of the first time driving a new truck at work. I pulled out the little metal key, but couldn't find a hole to stick it in. I had to get a kid in the office to come out and show me how it was done
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
rtaylor
R
ID
19Raptor, 22Bronco
I'm thinking the best solution these days would be to have a spare key/fob in the vehicle with the battery removed or taped over in combination with the keyless entry keypad. That way, if your original key is gone, you use the keyless entry pad to access your vehicle, put the battery in the spare key/fob and you're good to go
1 - You don't need a battery in the spare "hidden" fob. Just stick it in the backup slot in the center console and you can start the engine. Same thing for fob with water damage or dead battery.
2 - You can leave the battery in the hidden fob. As long as you have a second fob, it will disable the fob left inside the bronco (can be reenabled by pressing unlock on the disabled remote).
But you still need either keypad or cut key to gain entry.
Virtual-Chris
Virtual-Chris
North Vancouver
Get the door keypad and lock the key in the center console.
Interesting. I’ve not heard of the backup slot in the console. What is this all about?
I’m leaning towards adding the keypad on my vehicle. I didn’t consider it before, but it sounds like a great backup for entry, or even in situations where I’m meeting my wife at the vehicle… if she doesn’t have her key, she’s not hanging around outside waiting for me if she’s done before I am.
ps. My recent German cars won’t let me leave a fob in the car - it won’t lock. Ford is clearly a bit more sophisticated ;)
Silver-Bolt
Bill
Eureka, MT
If someone gets your door open they can drive away. The fob signal is not blocked by the console.
da_jokker
Jeep Wrangler JKUR
If you look on the owners manual there's a whole section about it. In the center console at the bottom there's an area that you can place a key fob in to program it, start the car if you need to, etc.
That's why I mentioned buying a third key fob right away, because you can use that slot to program it as long as you have the two original ones. Not sure how much they'll cost but it may be a good use of all the Ford reward points we're getting.
da_jokker
Jeep Wrangler JKUR
Yup.. there is literally no keyhole to put your key into. It is a push button start, so the mechanical key can unlock the doors, the glove box and the center console, But you need the chip inside the key fob to actually start the car.
da_jokker
Jeep Wrangler JKUR
are they really?
It's not that water will damage anything electrical (assuming you get it dries before it corrodes)... It is the shorting out due to water connecting the +/- somewhere at an exposed location.
Maybe the 3v battery doesn't produce enough jiuce to make that jump but electricity and water don't mix.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
So I took the keypad off my order because: a) it is an ugly stick on thing, and b) they stick it on in the middle of a beautiful body panel. I figure I will buy the stick on keypad and stick it in some location I want it (thinking on the black B Pillar rather than my CO door, but have read inside the fuel door if it will open when the vehicle is locked).
But yeah - this is the one usecase where the keypad makes sense to me.
604Bronco
British Columbia
www.bronco6g.com
Ha, my Audi would alert me if my phone was still in the car too. I found it to be super helpful and a great feature.
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
Uhh... there's a keyhole in the door handle. Just get a key cut.
At one time, I had a buddy at a Ford dealership that would make me a door key for $3. I expect a local locksmith could cut a “laser” one for under $20.
Silver-Bolt
Bill
Eureka, MT
When out in the wild I put my fob in a very small Pelican case which is then tethered to my backpack or chestpack depending on what gear I am wearing. I have SCUBA'd with it down to about 80 ft. I think the Pelican specs say it is good to 300ft. Keeps it dry and very good impact protection.
