Best Amazon Accessories
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
I like that Denier Bottle Pouch @VelocityBronco - easy to mount and stays in position?
The bottle pouch is sweet. Wasn't too hard to mount, comes with the molle straps to mount it, they are plastic, so a little hard to weave in and out, but took 5 minutes? Once mounted, they are solid.
I like that they zip up to make them a bit smaller, and look clean.
VelocityBronco
E
Have those deflators and I love them. However, the gauge goes to 80psi and isn’t super accurate at low PSI.
Found it under predicting by ~6psi compared to the dash. I’d used the dash or a better gauge to calibrate the deflators.
I was comparing the gauge to a digital gauge that I have and they were matching evenly down to 18 psi, which is where I have them set to right now, but I think I am going to go up to 25psi with them. I haven't used them with the Bronco yet, so I don't know if the TPMS will match my gauges, hope I get it close.
Deadlast76
Boston
I haven't looked them up yet (trying not to buy alot for a Bronco I don't have) but a short antenna and black lug nuts are gonna be early buys.
broadicustomworks
Hanging Rock, North Carolina
VelocityBronco
E
BlueBronco
DFW
helifino16
Ron
Mount Sinai, NY (Long Island)
Got this to mark my Parking Spot in the Garage:
Ford Bronco Best Amazon Accessories 1639058444746
VelocityBronco
E
NO! Many of what is labeled Torx Plus on Amazon are actually the Tamper Resistant 5 lobe torx bits and not what you need.
Try this instead:
Torx Plus - not 5 lobe
I just looked at my link, that is wrong and not what I purchased...I will edit my post. I bought the correct ones and they fit great, but they must be out of stock or not available currently. Thanks for catching that.
This is what I purchased:
Ford Bronco Best Amazon Accessories 1639058619965
broadicustomworks
Exact same thing I bought.
The link took us both to standard Torx...
although I do like the set @BlueBronco suggested as well.
timstrong20
Tim
Georgia
2010 Toyota Venza and 2020 Honda Civic Hatchback
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
I'm still avoiding buying accessories and mods until she's in my driveway It's getting harder and harder to resist though with posts like this.
VelocityBronco
E
Thanks for the links, do the Torx set include everything that you would need for the bronco, specifically the trim rings? Thanks in advace.
The torx plus set I linked was out of stock, and amazon was linking out to the wrong one, so I removed my link.
It has all the sizes, so it should cover everything that is torx plus on the Bronco. I haven't found any standard Torx screws yet, but they might have some mixed in there somewhere?
What trim rings are you asking about specifically? I can check later when I get home.
