WolfBox
Florent
LA
2021 2dr Bronco
Attention off-road enthusiasts and overlanders! We’re thrilled to announce the launch of our all-new Wolfbox HyperFlow 60D Air Compressor—a game-changer for your air inflation needs. Designed for durability, efficiency, and high performance, the HyperFlow 60D is built to handle even the toughest challenges. Here's why this powerhouse should be your go-to air compressor.
Purchase on Wolfbox site!
Purchase on Amazon!
Why Choose Wolfbox HyperFloew 60D Air Compressor?
  • 100% Duty Cycle: Can operate continuously for 60+ minutes under full load in 25℃ environments without stopping.
  • 40℃ High Heat Resistance: Performs exceptionally even in hot climates, working non-stop for 40 minutes.
  • Innovative Cooling: Dual-side active fan intake with an open heat dissipation design keeps the system cool under pressure.
  • Extreme Durability: Built for continuous high-load operations, with a core life of up to 80–100 hours.
  • High Output Performance: 5 CFM @ 40 PSI, ensuring quick and powerful inflation.
  • Perfect for Large Tires: Designed for 35–40” tires—inflate a 37-inch off-road tire from 10–40 PSI in just 3 minutes!
  • Auto Shut-Off: Set your desired tire pressure and let the compressor do the rest. It stops automatically with only ±2 PSI variance.
  • Multi-Wheel Inflation (Optional Accessory): With a high-pressure air source splitting into four independent airways controlled by solenoid valves, you can perform single-wheel, multi-wheel, or four-wheel simultaneous inflation. (Requires additional 4-Tire Inflation & Deflation System.)
Performance at Its Peak:
  • 120L/min flow rate at 40 PSI, ideal for fast and efficient inflation in every adventure.
Special Launch Discount:
  • Regular Price: $369.99
  • Introductory Price: $329.99 (Limited time only!)
Purchase on Amazon!
Looking for an On-Board Air Compressor?
If you’re into onboard setups, check out the Wolfbox HyperFlow X for the ultimate convenience.
Don’t miss out on this incredible deal—gear up with the Wolfbox HyperFlow 60D and conquer the trails without worry!
Available Now: Get yours today and experience inflation like never before!
Purchase on Amazon!
Frankie945
Frank
Louisville KY
Q50
I’ve been lucky to use this air compressor for a few weeks now and it really should be listed as a top tier air compressor. Not only is it fast but it has built in fans to keep it running at 100% duty cycle. You can literally air up your whole crew and it doesn’t get slow like other twin air compressors. It’s a 10 out 10 Wolfbox did an excellent job on it.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Good timing. My brushed ARB twin gave up the ghost on one cylinder after only 25m in the Utah heat and it was only 95F out. I'll keep an eye out for reviews.
Ninjak
Miami
That looks like a good unit. Wolfbox is making moves in the Off-Road space.
MDrums
Tampa
Bronco Raptor
I’m in the market for a portable air compressor and was waiting to see if Morrflate or EZFlate had sales…..possibly thinking of mounting a ARB on my rear cargo moLe…not sure……THEN THIS new one comes out and seems like a step up from the typical looking Morrflate /Ezflate .
Im paralyzed from choices and trying to figure what will be best for me. 🤣
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
Purchase on Amazon!
Purchase on Amazon!
Purchase on Amazon!
Wolfbox marketing meetings probably go a lot like this:
"How do we make it sound more powerful?"
"Add Mega."
"What if that's not enough?"
"Add Hyper."
"What if that's STILL not enough?"
"Add Super"
"What if that STILL doesn't cut it?"
"Put a number after it."
So now we've got:
HyperFlow 60D
HyperFlow X
MegaFlow 24
MegaFlow 24 Pro
MegaFlow 50
MegaFlow 500 Pro
MegaVolt 10Air
MegaVolt 16
MegaVolt 16Air
MegaVolt 24
MegaVolt 24Air
Super Power MF50
Super Power MF100
Super IR Night Vision Dash Cam
At this rate I'm holding out for the HyperMegaSuperFlow X Pro Air 24D Max IR Ultra Tactical Overland Edition. It'll offer more blow than a Colombian cartel shipment, air up every Bronco at Super Celebration, jump-start a dead battery from three states away, change your oil, improve your credit score, save your marriage, babysit your kids, and launch a satellite into low Earth orbit before you've put the valve caps back on. 🚀
Ask me how to save 10% off your next Wolfbox product order. 😀
G1D1UP
J.
Gilbert, AZ
2024 Ford Bronco Raptor
Any upcoming July 4th blowout pricing? For the $329 sale price, I could still hire a private sherpa to follow me around on the trail in a rickshaw, taking care of my meals, tires, snacks and portable Playstation needs. Come down a little lower for poor people who brutally financed a Bronco Rapor!
mdainsd
2025 Bronco, 1974 Bronco, 1969 Bronco, 2014 Raptor, 2012 MegaRex
Tough crowd :)
RynoRanger
Chuck
Gilbert, AZ
azbluey.com
2.7L Badlands NS 4dr
That's cool... i'd like to see some comparisons and perf deltas with what's on the market with similar looking twin compressors. But also... i'm in phoenix area.... running air on four 37" tires with environmental heat after hours on trail will definitely test it hard; I'd like to test that 40min 100% duty cycle :)
WolfBox
WolfBox
Florent
LA
2021 2dr Bronco
WolfBox
WolfBox
Florent
LA
2021 2dr Bronco
MDrums
Tampa
Bronco Raptor
For Wolfbox portable air compressor test review:
For Wolfbox onboard air compressor test review:
https://www.facebook.com/share/p/1E9NWnz83Y/
https://www.facebook.com/share/p/1Bt4pQgrRR/
That guy mentioned something about being sponsored on one of his videos. Not sure if I trust everything he claims and says, I hope I am wrong though.
Has anyone that has NO SKIN IN THE GAME tried one of these Wolfbox compressors out? I need an air compressor like last week!...I need to buy one now but waiting to see about 4th of July sales.
1- Considered the ARB Brushless with the manifold and 4 way tire deflate/inflate but looking at around $1300!!!! This can be mounted on my rear cargo molle side panels for a sweet set up just not sure it's worth double the price. I had ARB under the seat of a Jeep and it worked great though.
2- Considering either Morrflate or EzFlate with there 4 way deflate inflate hub system for around $780.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
They paid for Jody & Brittany to be in a TV series they footed the bill to record. Curtail expectations accordingly.
MDrums
Tampa
Bronco Raptor
Thanks yeah I am very skeptical on this brand or compressor.... just need to figure out if I want to hard mount wire in a ARB ( I tend to switch vehicles every 3yrs) or just get a Morrflate portable compressor. I was thinking of the Morrflate and attaching a wire from the battery and mounting an Anderson connector somewhere on the front or under bumper. Should be simple and easy?!?!
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
I love my ARB dual compressor paired with the Morrflate controller. I'd do it again 10 times over. And I say that as someone with a Wolfbox Dual Compressor sitting on on a shelf in my garage, because it didn't measure up to my ARB.
With that said, its a "just ok" unit that does the job. But it's more or less a rebranded ARB knock off and my personal preference was the real deal than an expensive knock off.
