Basic Recovery Gear?
shimmy825
James
Los Angeles
2017 Mazda CX-5
Looking for some basic off road recovery gear. I gather I need a recovery strap (vs a tow strap) and two soft shackles, correct?
Do I need D shackles (or whatever they're called) as well?
section525
Red Bluff CA
1975 Bronco
ARB makes some recovery kits that'll at least give you some ideas.
ARB Recovery Kits
I keep a tub in the back of my Superdooty with straps, shackles, battery jumper, air compressor, deflators, and a come-along. Depending on where you plan to go and get stuck will help determine what else you need. I like getting stranded in the snow so I keep a shovel back there too. 😜
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
The modular front bumper has the recovery hooks on the front, however they do have a sharp edge to them so not ideal for soft shackles.
Once Archetype racing (@EIGHTLUG) releases their front shackle in Carbonized Grey or Black I'll be picking those up and then using my soft shackles for the kinetic strap.
Traction boards can also be a useful resource depending on what kind of wheeling you're planning on. Snow or beach they're especially useful and can be used as a shovel.
shimmy825
James
Los Angeles
2017 Mazda CX-5
Thanks all
Bongo Fury
Bongo
Somewhere between point A and point B
2003 Ranger
Have yet to see anyone using one of these.......stump puller
The concept works leveraging upward while forward.
Pulled plenty of stumps in the past with half the effort of a direct pull.
Ford Bronco Basic Recovery Gear? 1642613735446
WuNgUn
Ontario Canada
2 door Squatched
The openings below the shackle mount is meant for soft shackles. The hole you're thinking about is to bolt a ring to. 👍🏻
Vantcrst
CA
92 Ford F-150, Mercedes 4x4 Sprinter Van,
That is correct. That area is specifically for soft shackles. If you are new to off roading and don't have a winch, then you should always travel with other vehicles. If traveling with others, then a kinetic strap and a couple of soft shackles will get you out of most situations. IF traveling alone then you need to consider methods of self-recovery i.e. winch, high jack etc. If you go that route, then you will need to add tree straps, a few more soft shackles and a recovery ring. I have a bunch of recovery gear that i custom tailor to each trip depending on the conditions I anticipate encountering. The further you get off the beaten track the more self-sufficent you need to be.
shimmy825
James
Los Angeles
2017 Mazda CX-5
very helpful and yes, beyond the off-rodeo, i've done nothing. I do not plan on going it alone, at least in the beginning. Thank you!
Vantcrst
CA
I would suggest going out with other more experienced folks when possible. Depending on where you live there are usually groups you can hook up with. Also, if you frequent popular areas for off-roading then even if you go alone there will be other folks out there to help if you run in to trouble. But as long as you are in an area with cell coverage and the weather is not life threatening then go explore. Just make sure you know how to safely operate any/all recovery gear you have.
WuNgUn
Ontario Canada
2 door Squatched
A come-along would work better than a hi-lift, and they're cheap. But a lot of work!
Headsong
ARB Recovery Kits
Hilarious. The weekender gives you a strap and shackles for 140 bucks! Oh, you get free gloves and a bag, too. Must be great gloves and bag.
Vantcrst
CA
Hi-lift's are also a lot more dangerous. Like everything else in life, recovery gear is all about tradeoffs. Cost, weight, size and capabilities.
JediMcMuffin
Tommy
2021 Bronco Badlands
Dead serious: Could you point me at a kit thats a better value?
Headsong
I just figure I could buy the strap and shackles for less than that? Haven't looked...where I go there ain't no trees within 1/4 mile, some 40 miles! lol But figure I'll carry a strap to help others out when needed.
