Base System Subwoofer Install
VictoryLights
Pittsburgh
2018 Honda Pilot
I upgraded all 6 speakers to Infinity Reference, and it’s definitely an upgrade over stock but I feel like a subwoofer would really finish it off nicely.
I’ve never installed a subwoofer, but it looks like you need access to both right and left channels. This seems tricky. Do you need to splice into the 6.5” speaker lines on each side and then run them to subwoofer? The consensus is that the rear pods are bass limited by the head unit so tapping in there won’t work.
fschael
Federico
Houston, Tx
2002 F-150 Supercrew FX4
Subwoofer are not stereo as far as I know. You might pinch it with one of the kick panels.
jhenson81
Jeremy
Quitman, MS
2015 F150
For best results, you should use both left and right channels as inputs for the amplifier. Then bridge the output (if using a 2-channel amp) for 1 sub. The reason being that some recordings may only have bass on the left or right channel. It would be easier if you splice into the speaker wires at the radio. That way you can run the wires together down one side of the truck. Also make sure you get an amp with Line Level inputs, if you're tapping into the factory speaker wires.
I'm sure YouTube has plenty of videos on basic subwoofer installs with factory head unit, just nothing Bronco specific.
F OR D
BD Green Machine
Love to hear what you did
threeonone
Canada
Jaguar
Mine was a powered sub. Tied into the rear 4" and it sounds great. Kenwood PA-W801B. Don't need an amp with it because it is powered.
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
For best results, you should use both left and right channels as inputs for the amplifier. Then bridge the output (if using a 2-channel amp) for 1 sub. The reason being that some recordings may only have bass on the left or right channel. It would be easier if you splice into the speaker wires at the radio. That way you can run the wires together down one side of the truck. Also make sure you get an amp with Line Level inputs, of you're tapping into the factory speaker wires.
Thank you. Getting at the 6.5” speakers on each side wasn’t too bad. I don’t have the confidence to rip the entire dash apart though lol.
Did you tie into both the left and right rear pods?
fschael
Federico
Houston, Tx
Clearly I don't know what I'm talking about... So, don't mind me.
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
I've installed 2 Kicker Hideaways in my past 2 trucks. They come powered and I've only tapped into one side instead both. Has worked out fine for me.
threeonone
Canada
Jaguar
It was done by a shop so I can't say 100%, but I'm fairly positive it's just the left side. That's where all my wiring is running. I chatted with the guy before the install and asked if they were going to tie into the 6.5" or the 4" and he said he always ties into the back speaker closest and never has had an issue. And honestly it sounds amazing.
Ford Bronco Base System Subwoofer Install AD012653-4906-41B0-BE3D-6F3DC8252304
fschael
Federico
Houston, Tx
wjfawb0 [hacked account]
Tennessee
2015 Jeep Wrangler JKR
When I installed a sub in my base 2015 Mustang GT, I tapped the left and right front channels at the radio, because Ford put a high pass crossover on the rear deck speakers in the Mustang. You either had to install a device that turned the bass back up on the rear channel, use Forscan to turn off factory equalizer, or tap the front channels. Who knows how they equalized the Bronco stereos.
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
Here's a good video of a sound system upgrade
Thanks, I’ve seen that video and it checks out with what @wjfawb0 is saying with the mustang rear speakers being high pass filtered.
When they connected their sub to the rear speakers it was unimpressive, but then switching to the front floor speakers made a huge difference.
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
Nice. I like the placement and look of yours. Is there anyway you could confirm how they connected it or post pictures of the connections? 🙏
