BASE SQUATCH first time in the snow using 4A.
EL in NH
Ernie
New Hampshire USA
2dr Basesquatch, 2005 HD springer,2010 sporty
Wet heavy snow..not very deep, maybe 5 inches. I tried both 4L and 4H, with and without the lockers. I dont know why but I was getting a lot of wheel spin
Not mashing the skinny peddle . I was starting to worry just a bit. Are these tires not capable of dealing with five inches of snow?
I dont know what was under the snow. What ever is there might be some of the reason.
In any case ,once I used 4A It settled down and I got to the plowed road with no further drama . 4A for the win. !
Ford Bronco BASE SQUATCH first time in the snow using 4A. 1 snow rd
SHANUT
Craig
Hermann, MO
I’ve never needed anything but 2H in snow but wet snow is very slick. 4L is not good for snow because it can induce tire spin more easily.
EL in NH
EL in NH
Ernie
New Hampshire USA
I’ve never needed anything but 2H in snow but wet snow is very slick. 2L is not good for snow because it can induce tire spin more easily.
You aint kidding about Low
SeptuagenarianSasquatch
Randall
4L and lockers are predominantly for off-roading situations. Stick with 4H for pavement.
(Emphasis added by poster)
I believe you mean "4H for pavement under slipper conditions--snow, ice, slush, sand, unpaved roadway, etc." Right?
Both tires on each axel move in unison in 4H, so the inside turning arc of one side is different from the turning arc of the other (outside) one. This means they're turning un-equally, which puts unequal pressure on the drive system.
Your wheels need to "slip" whenever you are in 4L or 4H, thus, never on dry pavement.
To the OP: That's an interesting experience, finding out that 4A worked best in medium, wet, snow. I guess the (computer's) brains outperformed the (4H + lockers) brawn. That's kind of unsettling to old-timers like me!
EL in NH
EL in NH
Ernie
New Hampshire USA
I was shocked ....I thought 4A was a gimmick. Not anymore. The performance difference was not subtle
Randall
It's a combination of sensors (wheel slippage), computer analysis, and delivery of power as (computer) directed. I've had two Toyota minivans (oh, the shame!😣): a Previa and a Sienna, both had them. The Previa was good (had to shovel out a couple of times), the Sienna superb (always got out, including being plowed in deep, up to the wheel wells. Okay, had to knock the tops of the plow furrows off a little. AWD (our "4A") is practically universal now.
Message me if you're going wheeling. I'd love to get more familiar with your Class 6 roads! I drive a 4DR BadSquatch.
WilVis
Northern Utah
Ford Bronco
Unless the snow is over 10 inches or so I use 4A exclusively. We get a lot of snow and my Basesquatch has done fantastic.
The other advantage is 4A basically is Subaru mode for my wife and daughter. No worries if the pavement is dry in between wet and snowy patches. (We have a Subaru Wilderness which seriously gives the Bronco a run for its money in snow.)
PWillette
Parrie
Maine
Lockers on snow/ice can make the slip & slide factor worse especially if off camber or steep inclines. Also, front lockers should be used sparingly no matter the situation to avoid undo stress on the CVs and steering components. Been at least a couple videos posted of pooched CVs from snow wheeling w/ lockers.
orion
Jeremy
17' F-250, 17' Explorer
Your thinking is wrong here. If locked axles, your description is true. Axles have differentials so the tires can travel at different speeds while turning. Just because you put it in 4H or 4L the differentials still let that happen. What doesn't slip anymore is the transfer case. So now the front shaft is spinning more than the rear shaft in a turn and that is what binds on dry pavement. When you go to 4H or 4L, your front and rear driveshafts are now locked together. The advanced T-Case has 4A and clutches also known as AWD. All areas are open, front diff, transfer case, and rear diff. This allows tire speed differential at the diff's and drive shaft speed differential at the transfer case.
Hope that helps some...
Arrowbear Rider
Marcus
Laguna Woods, Ca
Bronco, Triumph Thunderbird Commander 1700
Looking forward to trying out the 4A in the snow next week. I use to commute 22 miles through the mountains in a Tacoma and there were two tight curves where the snow always melted first and those would be clear when the rest of the road was still covered in snow or ice and I'd quickly switch out of 4WD and back for those turns, now I won't have to.
The Tacoma handled the snow wonderfully and I knew that truck like the back of my hand and how to drive it in the snow, it'll be interesting to drive the Bronco with 4A and see how it compares. I could drive the Tacoma in the snow and hardly use my brakes on the turns, just lift the throttle, I'll see how the Bronco feels on the same road using 4A.
1st 75th ranger
jeffrey
nj
for me 4a no traction control seems to work and yes i air down around 30psi
Scoop
Gary
Cuchara, Colorado
2026 Stroppe Edition, '74 Ranger, '76 Trail Rig, '05 F150 FX4
I live at 8600' in Colorado. We encounter lots of snow/ice covered roads. I've found Slippery Mode which engages 4A is the best for ice/snow on paved roads. I attended a snow wheeling event a couple weeks ago - the GOAT mode which worked best for off-roading in the snow was Mud/Ruts.
Beachbum
Lancaster, PA
2023 Bronco
I added sport mode to my Bronco just for the 4A option in snow. Worked like a charm in snow drifts a few weeks back.
BadBronc
Joshua
OH
This. I have no hesitation taking our Subaru Wilderness Forester up the beach or thru the snow. Doesn't have quite the clearance, but I echo your thoughts there.
Laddyaddy19
Landon
North Dakota
Nissan Altima, Evo X, F150
4A is definitely awesome in the snow especially when turning. The Bronco is a blast in the snow and reminds me of a heavy, more capable WRX STI or Lancer Evolution. It applies just the right amount of torque to each wheel to prevent spinouts. Personally, I have zero complaints with the stock tires in the snow. I have Falken Wildpeaks on my other rig, but the stock GY Territories are almost as good in the snow imo. Tire pressure makes a big difference. I keep my tire pressure from 32-34 for day to day driving in the winter. Some might go lower than that.
