Watching…
The rear pods only receive mid and high range frequencies from the head unit. Bass is filtered out at the head unit because the 4” speakers just can’t handle bass at higher volume. The front 4” and 6.5” speakers receive the full signal from the head unit, but the 4” has an inline capacitor to only allow mid and high frequencies, again because they can’t handle the bass at higher volume.New to this thread. Just took delivery a couple days ago, and yeah the base system really needs some upgrades. Overall I think the clarity is fine, but it has no depth and the pod speakers do next to nothing. I tried to read through this, but there's a lot here, so I'm sorry if this has been answered already. Does anyone know what the deal is with those pods? Why do they sound so quiet? Should I replace those speakers, or do they just need to be amplified? Thinking of basically just starting with an under seat sub amp combo. Is this kind of upgrade worth it?
But what makes no sense is that the rear pods also have base blockers installed (At least that's what I recall).The rear pods only receive mid and high range frequencies from the head unit. Bass is filtered out at the head unit because the 4” speakers just can’t handle bass at higher volume. The front 4” and 6.5” speakers receive the full signal from the head unit, but the 4” has an inline capacitor to only allow mid and high frequencies, again because they can’t handle the bass at higher volume.
They do not. The speakers in the rear have no filters on them.But what makes no sense is that the rear pods also have base blockers installed (At least that's what I recall).
Well if (stupid voice to text) that's true, that's so stupid. Why not just put filters on them like the rest, and leave the head unit alone to the people have options... Oh wait Ford... I get it.They do not. The speakers in the rear have no filters on them.
Because the audio to the dash speakers is piggy backed off of the kick panel speakers. The kick panel speakers can handle full frequency (or at least more than the dash speakers)What left that's true, that's so stupid. Why not just put filters on them like the rest, and leave the head unit alone to the people have options... Oh wait Ford... I get it.![]()
So, use the kick panel wires as the input for amp? Adjust gains for 4 channels fading front and rear volumes?Because the audio to the dash speakers is piggy backed off of the kick panel speakers. The kick panel speakers can handle full frequency (or at least more than the dash speakers)
Yes, definitely use the kick panel feed for any amp, but make sure you either use a line converter or an amp with high level inputs.So, use the kick panel wires as the input for amp? Adjust gains for 4 channels fading front and rear volumes?
Yes. I believe the amp I have chosen has high level adjustable input from 0.2V -9VYes, definitely use the kick panel feed for any amp, but make sure you either use a line converter or an amp with high level inputs.
TOTAL CHANNELSYes. I believe the amp I have chosen has high level adjustable input from 0.2V -9V
With? Any modifications or do they pop right in?Replaced my front four speakers and it's so much better.
They needed harnesses for both and the 6.5 inch just needed a plastic adapter.With? Any modifications or do they pop right in?
