Base Model Bronco Thread
dgorsett
colorado
F250, Mustang, Explorer
Are you saying 3.73 gears might struggle with the 33's without any other mods or struggle with the rear locker with 33's?
Any insight is appreciative because I don't know any of this mechanical stuff.
3.73 with a 33 inch tire and the very high (low numerically) overdrive gears in the automatic may struggle or hunt gears at highway speeds. Also, off road with the 2.72 transfer case it may not be low enough to crawl well. With the manual none of this is a problem as you can pick your gear on the highway and it has the crawler gear for off road so 3.73 is fine. The auto has a 4.71 first gear which is pretty low so it might be OK. Sometimes with and al a carte locker they are offered with lower (higher numerically 4.27 or 4.46) gears which would be good with an auto.
tokyo
Utah / Japan
2-dr BaseSquatch 2.7
I have 33's with 3.73 gears and the 2.7EB 10speed in my truck and it weighs similar to a 2-door bronco. It doesn't struggle at all. Perfect mix of in town acceleration and 80mph cruising. This is the exact combo I want on my Bronco.
As for the 2.3 I don't know.. Maybe someone with a Ranger can chime in as a similar combo would be possible there. I would think it will be fine.
I had a JK with the 3.8 gutless wonder motor with 35's and it was a dog.. vague steering as well. But with the top and doors off didn't matter, still super fun to drive around in.
Bronco_CA
SoCal
TIE Fighter
I think an actual base model will be a unicorn after preorders are built. Not enough profit for Ford or dealers.
Makes no sense. Base Bronco is a Wrangler Sport equivalent, of which Jeep makes and sells aplenty. I’d assume it will be no different for Ford. Higher trims will add more profit, but so will factory backed accessories for which Ford outfit the Wayne assembly plant, specifically for Bronco and Ranger. Those same accessories will go on Base Broncos.
tokyo
Utah / Japan
So dumb question here.. I have seen that the "adaptive cruise control" is not available on the base.. but regular cruise control is included right? I am not a fan of adaptive anyway
I think I saw someone earlier in the thread mention it does but I went through the list of features on the Ford website and couldn't find it mentioned.
I know on the F150 you have to get 101A I think to get cruise control maybe? can't remember.. Also I don't think the base Wrangler comes with it (or A/C) either.
I have to have cruise..
atonge40
Adam
Detroit, MI
2019 Ford Ranger XLT
Yes
Ford Bronco Base Model Bronco Thread 3948EF01-3BFC-41A0-A7B8-E304496B0117
dgorsett
colorado
Yes, I would imagine a locker may be available in one of the ratios already offered on other models, 4.27, 4.46 or 4.7.
tokyo
Utah / Japan
Thanks! I did see that but was afraid it was just the "controls" .. like a place holder or the switch blanks or something and not the actual cruise control. Or even worse some mis-print or wording that was accidently carried over from one of the higher packages.
Glad to hear its legit!
Now just need the stand alone rear e-locker option and I'm golden.
Nickp
Nickp
Nick
Phoenix
NickP please verify... I thought I saw somewhere Sasq is not available on Base model with manual, only with the 10-speed auto tranny. Thanks. Where in AZ are you, I road trip to AZ to see my parents couple times a year...
It is, I posted that right after the reveal When we weren’t aware. There’s a rumor that there might be a “Sasquatch lite” with just the axle/lift that you can get with the manual but only time will tell.
I’m in Scottsdale, I’m sure we are going to have an active Bronco community out here so make sure to join in if possible!
Bronco_CA
SoCal
TIE Fighter
Or Detroit Locker? ARB requires an onboard compressor, right?
Never heard of that. Sounds like you’re referring to the onboard air compressor for airing down/up tires. That’s an entirely different thing.
atonge40
Adam
Detroit, MI
I thought ARB lockers were air lockers that required a compressor.
Garbone
Gary
FL
Electronic-locking Front and Rear Axle
Is listed as a available option.
So we are set, now to see the prices
