Base Model Bronco Thread
BDBrian1
Philadelphia
Ford Edge
Base of Bases here. In Oxford White no less! The only options I ordered were Aux switches, Splash guards, floor protectors, Paint Protection film and cargo protector. That's it. Nada, Nuthin, zip else. $30,985 with Destination & delivery. Build week of 7/12...
Anyone else have this build?
I have the same build same color upgraded bumper also the same build week!
TJconvert2.7
New England
Sooooo......... do they make 33” all seasons?! 😁
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
Only added the up fitter switches and the door access keypad. Cheap and easy.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I'm surprised Ford don't offer 32" all terrain tires as standard
I suspect a lot of it has to do with maxing out MPGs. That and they like to give you a reason to go up a model and spend more.
Bronco55
Tim
New Jersey
2014 Ford Fusion, 2007 F150 FX4
Have one reserved in Antimatter Blue for the wife but we got that "delayed" email and no build date either. So, I just got her a 1973 Bronco in the mean time.
Yes, I have an Antimatter Blue order. Build week scheduled for 7/12
ATHIKER
Bill
Toyota Corolla
I'm playing with that idea also, but the heated seats of the Big Bend and Black Diamond are tough for me to get past.....but that price point though!!!
edit... of course, Sasquatch.
dealer installed heated seats will be added for $500-$600 to my Base, 2dr, 7 speed, mod bumper, roof rails, Oxford White
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
At that price I wonder if the heat pads are already in the seats and it’s just a matter of adding the harness and switch?
R11
Rob
Sparta, Tennessee
www.basequatch.com
Bronco Base Sasquatch 2.7
Tell me more! Any specifics on parts and where the switch will be?
ATHIKER
Bill
Toyota Corolla
From what I understand the dealer does remove the seat cover to install the aftermarket heating element but they do not wire to the factory switch location. The switch ends up on the side of the seat.
ATHIKER
Bill
Toyota Corolla
just google dealer installed heated seats for comments
Sooner
Ted
Henryetta, Ok
You can get it on Amazon for $200
I was wrong, it’s $52.99 for two complete sets.
DebbieEF
Debbie
Ford Mustang and F250 SD truck
First post here.
For those curious to see how 33" all terrain tires would look on the base with the polished steelies then I mocked these up in Photoshop.
I think this looks fantastic, the proportions with 33" tires look just right for the 2 door. The 35" tires are better suited on the 4 door.
I'm surprised Ford don't offer 32" all terrain tires as standard with the base or as an upgrade (gloss black 17" steelies) considering it would provide a little more ground clearance to match that in the base Wrangler.
I dread to think how many hours I've spent on that configurator going back and forth with options. I'm constantly torn between the Base and the Black Diamond, it seems like there's so many options but too many compromises to get the perfect configuration that I'm after.
Decided not to get carried away with all the bells and whistles and to stick with the base and then upgrade to 32"/33" tires later for the minimal off-roading I'll be doing.
Money I save can go to other things since a $7k jump to Black Diamond isn't justified IMO which is the only alternative option I like that doesn't break the bank.
This base configuration comes in at $33,920.
Mcuncle, how do you price out adding the 33 inch tires to the base? Size on the 16 inch rims? Thank you, Debbie
