Base Model Bronco Thread
Tangent27
Tim
Indiana
2013 VW Passat 2013 Road King 1987 BMW e30
I think it would be front locker rear locker and I think hazards are up there too but I might be mistaken. Sway bar disconnect would only be on badlands.
DonM
Don
Northern Cincinnati
2021 4DR Base Sasquatch 2.3 in VB
I’m just curious, does anyone know what hero switches come with the 2-dr base and Sasquatch package?
Front and rear locker, probably?
DonM
Don
Northern Cincinnati
Doc Rocket
US
Ford Bronco, Base, Sasquatch
Hazards, Traction Control off (these two are on all), Trail Turn (if auto), Front Locker, Rear Locker.
LandCruiser
Bocephias
CA
So Ford says no MT with Sasquatch until later in 2021.
You have to B&P a 2021 in December-January, where the MT won't be available as an option.
So how would you go about getting a 2021 MT Sasquatch when you can't order it and once your order is in it can't be changed?
mdepll
mike
toronto
sorento
No tow package for the Base has been known for a long time.
That said;
if you are buying a Base thinking that you won't have to wrench in exactly what you prefer, the Big Bend is your answer.
what does wrench in exactly what you prefer mean ??
Atomicdog
Eddie
Philadelphia
Thank you! As the b&p stands now I may have a full bank, but 4 at least.
Atomicdog
Eddie
Philadelphia
There is some speculation that any "Late Availability" options will be MY 2022.
This is why I may get the auto.
dingle87
Reese
West Suburbs of Chicago
2019 Ford Explorer XLT
The dealer order “form/process” will have those details. B&P is just for the customer to get an idea what we want along with a general idea of price. It sucks not having it on B&P, but it’ll happen. There’s other potential glitches I’m wondering about with it that’ll hopefully get cleared up.
Doc Rocket
US
The Ford build and price page, indicates 4.46 axle gearing, for the base manual trans Bronco. What do you guys think of that? Seems kind of an aggressive gearing for only 30" stock tires. In that case, maybe the 4.46 gearing will be OK for larger aftermarket tires up to the 33" range?
This is also the factory ratio for Black Diamond (manual and auto) and Badlands (auto), so they should be fine with 33's.
Drinxxs04
Anthony
Wisconsin
Jeep Grand Cherokee
Through your dealership they will be able to order late availability setup. They will have a much more detailed order catalog...with more accessories as well.
Doc Rocket
US
Interesting. Yeah I am hoping the stated diff gearing is not a B&P mistake. Because that should mean I could put 33" tires on the base model, and still have decent gearing, without having to swap R&Ps.
I was looking at this chart shown below, showing rpm for various tire diameters/diff ratios. For when the trans is in 1:1 drive gear (meaning not overdrive). 33" tires with 4.46 diff gearing, would land in the green zone.
I got it from the "Bronco Preliminary Tech Specs" document released in July. That does not seem like the kind of thing they would be changing much. Basically, there were only 4 total gear ratios available: 3.73 for autos on everything non-Sasquatch except Badlands and Black Diamond (with a 4:27 for autos in Big Bend and Outerbanks--maybe the locker ratio?), 4.46 for manuals except for Badlands, and 4.7 for Sasquatch. I don't see a good reason to change that all up.
Incognito
Phoenix
2017 jk
Very true, except.......
The 10A has 3 OD gears.
If you went with unobtanium 5.38 gears, the turbo would kick in on the drop from 10th to 9th.
Please don't mention MPG.
I cruise my lifted, topless and doorless 4x4 at 75mph down the highway.
