Base bronco Rear pod light install question
Grift3r
2022 Bronco Squatch
Hey all,
So I'm looking at the DV8 rear bumper with pod lights. The question is, how hard is it to wire the rear pod lights? Is there already a connector there? I have a Basesquatch with no add-ons (no trailer or aux switches) so I'm wondering if anyone has already done this and knows. Thanks!
Cobrafang
Thomas
GA
I just used this.
https://www.4x4truckleds.com/crysta...rness-for-baja-designs-s1-s2-squadron-lights/
Had to cut off the harness connectors because they are not compatible with the wiring harness on the DV8 elite lights. No big deal install. Wired it into the number 4 aux switche's brown wire then routed it down the drivers side along the frame using the existing wire harness on the outside edge of the frame. EASY peezy....some people wire them into the back up lights and DV8 may have a harness for that....but I wanted to choose when they were on or off.
Lifeliberty
Moonbeam👀
Columbus, OH
I just used this.
He doesn't have aux switches
Try @4x4TruckLEDs.com
Grift3r
Grift3r
2022 Bronco Squatch
I reached out to DV8 and their pod lights do just hook to a trailer harness, or the tail lights for backup lights
