Base Audio Upgrade and Forscan
VictoryLights
Pittsburgh
2018 Honda Pilot
I have upgraded all 6 of my speakers to Infinity Reference with 300Hz bass blockers on the fronts. I definitely notice an improvement in clarity, but overall I’m a little disappointed. These speakers should sound better than they do IMO.
I ran across this mustang video and I’m wondering if it could be the missing piece. He also installed Infinity Reference speakers and was initially underwhelmed. Then, he used forscan to disable the stock stereo from filtering the speakers and the system came alive.
I’m wondering if Bronco has a similar forscan accessible control.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
*Following
However, I believe I've seen this referenced before and the reason it was being done was that the filtering was blocking a subwoofer tapping signal off of some speakers and the low frequencies were almost wholly pruned. I would however like to hear more about this :) I am going to post in the ForScan thread for you.
EDIT: I posted here on your behalf (and mine) :)
https://www.bronco6g.com/forum/threads/2021-bronco-forscan-thread.844/page-23#post-973110
Hossfire
Richmond, VA
'06 Jeep Commander
I have read that there have been issues with upgrading the kick panel speakers. You might try swapping the factory ones in just for them to see if that makes the sound better. My guess is that the factory radio has a DSP specifically tuned to that (low quality) woofer. Now, what makes that a little interesting is that the best result for running an aftermarket sub is splicing from one of those kick panel wires. Maybe the DSP is tuned to just the high and mid range, and the lows have a base blocker right at the speaker? It's a conundrum. Maybe the folks at Crutchfield have figured it out.
Hossfire
Richmond, VA
'06 Jeep Commander
Also, the B&O reportedly has a somewhat mediocre sub/ sub amp. Not that I would want a crazy bone-shaking machine. I may move my 8" Polk MoMo/ Rockford Fosgate mono into my "imaginary Wildtrak" to tighten up the bass definition. I may need to break out my Thiele Small calculator and redesign the enclosure to fit the fold down height of the back seat.
JediMcMuffin
Tommy
Just finished adding Kicker CSC4s to the rear pods. I do believe there is some upstream frequency filtering. My CSC4s in the front felt like they came alive when I swapped those but these hardly seem any different.
JediMcMuffin
Tommy
I found this comment on F150 Forum useful in regards to attempting alter the EQ:
Ford Bronco Base Audio Upgrade and Forscan 1637275973549
I'm inclined now to just leave things along back there, and I never intend to add a subwoofer so I doubt any of the more advanced changes are necessary. I am still on the fence on if I'm going to install the kick panel speakers.
qbd1414
Jessica
Charles Town, WV
Chrysler Pacifica
I just added the two rear speakers and noticed no difference ... it didn't sound good, but maybe better than the stock speakers. I added the front ones yesterday and you can tell the difference but not sure if I like the front 2-way speakers... I just want a speaker that I can hear music like I do with my bluetooth speakers... I don't understand why it is so hard to research audio!!! I just ordered a 4 way speaker to see if I like that better it was cheaper and probably less powerful but I just don't like how a 2 way speaker is separating the sounds. Again it sounds better than the standard speakers... I figured out the door kick panels must but the base / woofers so unsure if you change those it will help with the front speakers--- but the front sounds ten time better than the back. The back does not connect to the front kick panels for base so I think the 2 ways need the base connection.
I really need an audio for dummy I had to stare at wires today ... I figured out the diagram and colors then opened the speakers to only have the two colors connected to two black wires!!!! gees thanks!!!!
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
Thank you for this. I’m thinking the Bronco could be setup similarly. The Pickens Party of 5 subwoofer install didn’t work well when they were connected to the rear speakers and then came alive when connected to the fronts. This makes a lot of sense if the rears are 50 hz high pass filtered.
Maybe I need to play with my basic eq settings or consider adding a sub. I just haven’t thought of a clean way to run the left and right front channels to a sub in the rear.
Geo
Geo
Ford Mustang
Is there room for a 5.5 speaker in the rear?
PapaWE
Ohio
89 Chevy K2500, 07 HD Nightrain
This is what I am finding out. Factory kicks sound ok. Good mid bass. The area they are mounted in is built like a ported box with the port located at the bottom. I changed them out for JBL's and the bass pretty much went away. EQ cranked all the way up and yet mid bass gone and low bass quiet. I am thinking that the factory head is tuned for the factory speakers. I also bought front and rears but haven't done anything yet cause I'm trying to figure out if someone will find a forscan answer. Either that or I'm going to add something like the kicker key amp and DSP. This is the most ridiculous system I have ever dealt with
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
All these audio threads keep pointing me into the same direction.
Buy a DSP4068 and learn to tune speakers. I wonder if I install it myself, would a stereo shop tune them for me?
Hossfire
Richmond, VA
'06 Jeep Commander
It's a shame that these factory head units don`t include an easily accessible set of pre-amp outputs.
DarkPony
Clint
Tulsa
2018 Ford F250 Platinum, 97 Porsche 993
If you really want to see noticeable gains you need to get a digital signal processor, it will open up any system and give you a ton of flexibility. I prefer a Rockford Fosgate 360, programed correctly it will blow your mind. Keep in mind the Bronco is not designed for sound fidelity and doesn't have any sound deadening whatsoever so at some point you just get what you get.
