Base audio system line level interface possible | mObridge
mObridge
mObridge
Fraser
Orange County, California
BMW e92 328
YES! If you could change the bass EQ to only affect the subwoofer output I would buy the bronco kit. To set this up, should I have the bass eq maxed out and then set my subwoofer gain in the dsp? This way I will never run into clipping when the bass eq is all the way up?
The bass EQ will directly set the subwoofer gain, so we have a max gain of +9db on the subwoofer so max bass eq would then be +9 Minimum on the bass eq will now be 0db gain on the subwoofer. When you change the bass eq you will see it directly change the gain setting on the subwoofer channel on our PC tuning tool. You can setup a dynamic channel limit on the subwoofer channel to whatever power level your sub clips to prevent clipping.
Keep in mind, the kit is also only compatible with the B&O system currently. We will have a non B&O solution in the new year.
Geomanis
George
Boston
VW GTI and Ford Ranger Edge 5spd
Ok, that sounds great. I do have the B&O system. So should I just purchase through your website and send you an email about the software change?
Thank you!
mObridge
mObridge
Fraser
BMW e92 328
Draughon
Daylon
Dallas
BMW 4-Series
Does anyone have install pics / can give guidance on installing the Mobridge PnP into a 2-Door Bronco?
kojack19
CT
Ford F150 Raptor
Coming soon! maybe 2-3 months.
following this thread. Have installed new speakers and pods. better but still want to do more without going crazy-at the end of the day, the top is off a lot and the bronco was def not designed for good sound based on lack of insulation and speaker placement.
braddavis2017
Bradley
Breinigsville, PA
Ford Bronco
mObridge
mObridge
Fraser
BMW e92 328
I wanted to check in and see if there have been any updates on the availability of the non B&O system, since it’s been a couple of months. Any new developments?
Thanks!
No further update on this unfortunately, we have been swamped with other projects and only have so much bandwidth for R&D!
braddavis2017
Bradley
Breinigsville, PA
Ford Bronco
No worries. Thanks again as always for the transparency and quick responses, it’s super appreciated!
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
It wasn't difficult, just running a couple of wires and a bit of work on the sub enclosure...
Ford Bronco Base audio system line level interface possible | mObridge tune 7
i911fire
Ryan
Kansas
2023 Code Orange BRaptor
I just go the Trail Seven Alpine S speaker bundle with the 6.5" Raptor Friendly rear pods. The sound is so much better with better speakers. However more power to push would sound much better in addition to getting some real power to the rear pods.
Any mObridge deals or discounts happening? I have been looking at that system or doing a PAC audio with amps like I did in my previous wranglers.
mObridge
mObridge
Fraser
BMW e92 328
Send me a direct message!
