Bar/Hoop Installed on Capable Bumper
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
I installed a JK bar to my capable bumper since I couldn't find one made for the capable bumper. My install went like this:
1 - remove bumper
2 - drill holes
3 - bolt on bar
4 - re-install bumper
Ford Bronco Bar/Hoop Installed on Capable Bumper Front KC
Ford Bronco Bar/Hoop Installed on Capable Bumper KC Bar side
Ford Bronco Bar/Hoop Installed on Capable Bumper front corner 2
Mo2199
Atlanta
What did you use to screw in the bar? Washer and torx?
DJ1
DJ1
Minnesota
Nuts, bolts and washers. The bar came with a back plate that has nuts/threads welded on, but I couldn't fit the plate inside the contours of the bumper. I just used large washers to try and distribute the load.
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
Wow that looks great! What bar did you use exactly? Do you have a link?
NatureBoy
Virginia Beach
2022 Base Bronco
1 - remove bumper
2 - drill holes
3 - bolt on bar
Somebody get this guy a beer.
Meloco
Bronco edge excape
So I just got my Amazon bull bar and the number mount is way bigger the what I have seen on the others that have done this
Ford Bronco Bar/Hoop Installed on Capable Bumper 20230727_190918
Ford Bronco Bar/Hoop Installed on Capable Bumper 20230727_190908
Meloco
Bronco edge excape
Thinking about this, it fits but the few comments I have seen people hate it.
Ford Bronco Bar/Hoop Installed on Capable Bumper Screenshot_20230727_204300_Chrom
GI_Jo_Nathan
Jonathan
That sucks. Got a link to the one you bought?
That other one is on the plastic bumper not the Capable. Could possibly work, but probably not.
Meloco
Bronco edge excape
The other one I posted actually has instructions for a capable bumper
Meloco
Bronco edge excape
So learned a few things that made it fit.
When I loosen the bumper, it probably dropped 3/4 of a inch. I also put a washer the 6 bolts that mount the bumper. That allowed me to raise the bumper back up a little, not to where it was but closer.
Ford Bronco Bar/Hoop Installed on Capable Bumper 20230729_140952
