Status
Not open for further replies.
BAMF
Jerry
Benicia CA
www.bayareametalfab.com
Two 2021 Broncos
Our Overland winch bumper is build to beat. Constructed of a mix of 1/4" and 3/16th" steel. The winch plate is the start of it all it's where the beef starts 1/4" plate formed and gusseted for those hard winch pulls. The winch is set lower directly in front of the frame rails reducing the lever arm pulling action you would get from it mounted above the bumper. The recessed winch mount limits you to the smaller size 10k winches like the WARN Evo10k/12K and relocation the solenoid is required/recommended with most winches. have a under hood kit available as well for the WARN Evo winches to relocate the solenoid to the engine bay.
https://www.bayareametalfab.com/FORD-Bronco-Overland-Front-Winch-Bumper-21_p_175.html
The top of the bumper is left open with a lower air intake hole As well as the Stainless steel mesh vents to allow air flow to the intercooler directly behind it. We have tested this set up blocked with a Warn EVO 10k winch. With just over 2500 miles towing our X-100 expo trailer, up grades towing at 80mph with 95 degree ambient temps, Daily street driving, low and slow off road, go fast off road driving. all with no engine cooling issues on the 2.7L.
100% made in the USA!
Ford Bronco BAMF Overland front winch bumper 20220203_163516-01
Ford Bronco BAMF Overland front winch bumper 20220203_162336-01
Ford Bronco BAMF Overland front winch bumper 20220203_163509-01
Ford Bronco BAMF Overland front winch bumper 20220203_163544-01
Ford Bronco BAMF Overland front winch bumper 20220203_162314-01
Ford Bronco BAMF Overland front winch bumper 20220203_163504-01
Ford Bronco BAMF Overland front winch bumper 20220203_161610-01
We tucked the main section as far back as possible without cutting into the frame horns. It would be hard to find recessed a winch bumper tucked tighter than ours that doesn't require cutting. That limits you to the smaller platform winches like the Warn EVO 10k or 12k. The winch is a very tight fit so relocation of the solenoid is required in order to raise the bumper all the way to the grille.
Ford Bronco BAMF Overland front winch bumper 20220203_161645-01
Ford Bronco BAMF Overland front winch bumper 20220203_161623-02
Ford Bronco BAMF Overland front winch bumper 20220203_161617-01
Our D ring mounts are Cut from 3/4" plate steel and tumbled for 18 hours to soften the edges.
They are a full passthrough welded 5" along the winch plate for worry free recoveries.
The laser cut mesh air vent plates are made from tumbled finished 14 gauge 304 stainless steel. They can be left raw or you can paint them to accent your build.
Ford Bronco BAMF Overland front winch bumper 20210915_081513-01
Our powder coating "Included" is unlike anything else in the industry.
It's a completely field repairable thermoplastic coating you can fix with a heat gun or blow torch
(Yeah I said you can fix it with FIRE!). Laid on ultra thick for long lasting protection you will not see anything else like it on the market well that's until they all start using it.
In cab camera views
No bull bar
Ford Bronco BAMF Overland front winch bumper 20211207_164321
With bull bar and four KC flex LEDs blocks some but not all of the view.
Ford Bronco BAMF Overland front winch bumper 20220128_154121
AZBronco73
AZ
2022 Badlands SAS, 2015 Dodge Durango
what is the max width for a winch that will fit this bumper?
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Good looking solution overall.
Do you also offer a relocation kit for the ACC radar? And if so, have you actually verified the ACC works afterwards?
Marauder
Josh
St Louis
thattrue32
Erny
Fairfield CA
1932 Ford Pickup
  • Like
Reactions: jxc
Marauder
Josh
St Louis
Yes he has our Hybrid prototype with the tube wings.
i love the Halo lights across the roof, but I can’t unsee the pacifier
Ford Bronco BAMF Overland front winch bumper 1644007438783
BAMF
BAMF
Jerry
Benicia CA
Two 2021 Broncos
It looks like these don't incorporate the parking sensors?
take that back i see your website offers them! badass
Yeah this Badlands has no parking sensors in it so no holes if not equipped with the sensors.. I'll have pics up with the parking sensors installed on a stock non sasquatch badlands next week.
BAMF
BAMF
Jerry
Benicia CA
Two 2021 Broncos
Yes and we have. Our bracket relocates it behind the grille just below the R. No function issues or recalibrations as of today. We have been testing it for a few months with great results, we don't have 10's of thousands of miles using it yet but it works perfectly with no codes or errors on our mules.
Ford Bronco BAMF Overland front winch bumper 20220120_143042-01
Ford Bronco BAMF Overland front winch bumper 20220121_165614-01
Jr87mustang
Josh
Northern Cali
Already ordered, looks really good.
Status
