Badlands GOAT mode question
GAN
Gan
RI
Bronco Badlands, Ford Escape, Hyundai Tucson
I just ordered my Badlands non-SAS back in March with a 5/26 production date but have a question on the fact that it will not have a Sport Mode. Im out in Moab now and did the Off-Roadeo Friday -which was fabulous by the way. In the National Parks there are many paved, winding mountain roads …what’s the best mode to be in for this type of driving? My other car is a small SUV and dropping that into Sport would stick those with no issue. We used Baja mode during Off-Roadeo which was awesome, but with the hard shifts at 4500-5000 rpm that’s not really what I’m looking for. Thoughts?
RagnarKon
Ford Bronco, Escape, Focus
Baja mode, and then turn the transfer case to 4-Auto (if memory serves... by default it is set to 4-High).
Or you can just turn on Sport mode via Forscan.
GAN
GAN
Gan
RI
Okay I’ll give that a try today. I’ve got a Badlands SAS while out here that I rented off Turo so I’ll see how that goes. But when I eventually get mine, I’ll probably look to add the Sport via Forscan. Thank you for the tip!
Vanimalious
Nicholas
Ford Ranger
I also have a badlands. Whenever I need that thrill, I switch to economy mode for a tank of gas, then go back to normal mode. I've heard of people doing the forscan trick to add sport mode, but I've also heard it sometimes throws error codes as well or something like that. Enough that some have had to remove sport mode(not sure if it was user error).
Was talking to a guy about it and he said he'd never get a bronco because he likes driving fast too much(he was all about the Honda Genesis or something like that). I told him that's fine, I don't need to drive fast, just wherever I want.
  • Like
Reactions: GAN
GAN
GAN
Gan
RI
Not necessarily looking for a thrill …throttle response -sure. But the main purpose would be for the steering and handling benefits.
Vanimalious
Nicholas
Ford Ranger
I knew goat mades changed throttle control and trans shift points. I was unaware it also changes steering and handling. I may have to look into this further for myself...
I'd imagine much like early 90's turbo lag, if you drive it long enough, your conform to the vehicle. I came from a 92 Toyota pickup, so bronco has plenty of pep, but I also do some... 'spirited driving' on occasion. I was not prepared for the fifteen feet of body roll on the SAS suspension. After driving the bronco for 8 months, everything doesn't fly to either side of the vehicle anymore on turns.
  • Like
Reactions: GAN
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I have activated sport mode on my own BL and several others via forscan, and it did not create any errors. Remember to clear all codes after you are done (sometimes codes get set during the write process because the module has to go offline briefly). Also have found Baha mode/2hi/rear locker on to be a fun mode for dirt roads!
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
I would put sport mode on with forscan. I have baja on a black diamond and I think baja holds the shift points longer than sport. To me its a bit too agressive for street driving in 2h, off pavement is another story.
Mattyfly42
2021 4 door 2.3L MT
I have a pedal commander and the ford performance tune. That is my sport mode. Also wondering if it's worth forscaning sport mode if I already have those mods if it would make a difference. Can anybody chime in on that?
GAN
GAN
Gan
RI
That’s exactly what I’m saying. But fun as all hell on dirt roads!
the poacher
john
Whistler
2010 ford ranger
As you correctly stated, there is no Sport mode with the Badlands model. As long as you run premium fuel in your Badlands, Normal mode will provide you with all the pep you need to easily handle winding, mountain roads.
Or, as some have alluded to, you could go into Forscan and change the settings to give your Badlands a Sport mode.
  • Like
Reactions: GAN
Bmadda
Wisconsin USA
Biggest thing w/sport mode is the change in AT shift points...mine is a MT, so sport mode does virtually nothing for me, but the AT guys all love it. Not sure how pedal commander fits into the equation...I have one of those too, but rarely use it (MT), and IDK if it also alters the shift points on an AT, or just the throttle mapping...but I can tell you the #1 feedback from everybody who wants sport mode unlocked, is AT shifting is so much better. Couldn't tell you if the FP tune alters AT strategy either, but I do know that improved AT shift strategy can make an automatic trans vehicle feel so much better...even going back to the days of shift kits we used to put in "dumb automatics". Just my opinion, but I believe the love we see for sport mode comes mainly from the auto trans strategy built into it...people just love the way they set it up for AT!
  • Like
Reactions: GAN
GAN
GAN
Gan
RI
Okay thanks all for the info! So if I’m understanding correctly, Bronco Sport Mode will only impact throttle response. Not, like some vehicles with active suspensions that can change the stiffness of their dampers causing the body to roll and bounce less. Some also change the amount of assistance from the power steering system in Sport, making the steering wheel feel heavier and the car more substantive — or even change the steering ratio, so every degree of turn has a greater effect. Good to know 👍
Mattyfly42
2021 4 door 2.3L MT
Yeah. I have the MT so don't really see the need to start messing with sport mode. Can't imagine it any better the I have it set up.
Bmadda
Wisconsin USA
Ya I have it enabled on mine, and I have FP tune and pedal commander and it's like "so what?" Probably you wont notice a difference then
