Badlands Badge to Grill Relocation Kit
jedmisten
Joseph
CA
Ford Ranger and Ford Flex
I put my extra one on a clear piece of plastic for possible use later..FYI relocated to grille after several weeks in various weather conditions ..looks perfect.
Finished product
Ford Bronco Badlands Badge to Grill Relocation Kit 7A164B31-F3BC-4ACD-B17B-C403BFC8A7B9
Ford Bronco Badlands Badge to Grill Relocation Kit F3AEFA8F-F94A-42ED-9394-3A2F3A58F179
Ford Bronco Badlands Badge to Grill Relocation Kit E9ABB6CC-1AAD-4CF7-9D01-BD561FE2D136
Ford Bronco Badlands Badge to Grill Relocation Kit ABAE923D-43BD-434B-92AB-7A1372E9CFCA
BroncoBuckaroo
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Oh I like it
Perfect-Beast-2
Rick
Virginia and NJ
1973 F100 / 1980 F150 Stepside / 2019 F150 Lariat
Kit will require (2) M5x30 cap head screws and (2) M5 nuts. I recommend using threadlocker on the screws to ensure they don't vibrate loose.
Assemble the kit by inserting nuts into the small locking bars. A dab of hot glue will keep the nut in place, just thread the screw in first to keep glue out of the threads!
Now put the screws through the holes of the badge plate. Push the grill inserts over the screws with the cut outs facing the rear. Then thread the locking bars on but not tight. Completed assembly should look like the image below but with both pieces assembled.
Next find the right spot on your grill! With the the inserts in the grill, spin the screws 90* and then use a screw driver, magnet, or similar to pull the screw head forward. With the screw pulled forward starting tightening the screw. Be careful not to over-tighten, remember these are plastic parts tightening onto a plastic grill.
With the badge relocation kit properly affixed to the grill, give it a wipe with alcohol and then adhere the badge. I recommend a spray adhesive to help the badge adhere to the rough texture of the 3D printed surface. That's it!
Will you be making the badge relocation kit for other trims and other grills?
  • Like
Reactions: Cat
BroncoBuckaroo
Missouri
not sure, I’m not the maker, but I do have an additional Outer Banks grille I will be swapping that I would like to move the badlands badge to..we will see what Colintrax can come up with.
colintrax
colintrax
Georgia
Chevy Colorado, Ford Explorer, KTM 890 ADV
I'll be adding the Wildtrak sometime soon.
Base and Black Diamond are possibilities but I don't believe the Big Bend and Outer Banks aren't worth doing with such large grill openings.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
This is a great idea.
I would move it one slot inboard.
atimberwolf
Ford Raptor
I'm interested in one for the BD when you get it sorted out.
NOVA Bronco
Ryan
Northern Virginia
Toyota
Finished product
Really like how you added it as a tow hitch cover. Makes me wish I would have gotten the tow package just so I could copy this.!
colintrax
colintrax
Georgia
12/27 product update.
I'm taking orders for these again and will be releasing a Wildtrak kit soon. Any Wildtrak owners that want to test please shoot me a PM.
I had a kit returned from USPS due to a "security concern." I couldn't get any reason what that would be but the employee at USPS suggested I use boxes instead. So, I'll now be shipping in boxes instead of a padded envelope. Being in a box, I'm including the hardware and preassembling the kits. To account for these changes, the price has been increased from $10 to $20 with free shipping.
The grill insert piece has also been modified to ease installation.
With the new hardware installation will only require a #2 Phillips drive screwdriver.
LoneWolf1903
Caleb
Tennessee
2021 Ford Bronco Badlands
How do we order?
colintrax
colintrax
Georgia
Is there a hitch cover kit available?
The trailer hitch idea was @jedmisten. He used a hitch plug he already owned and attached my plate to it.
I'm not currently selling a kit for the trailer hitch and don't have plans on doing so. The time and cost to make the part that fits into the trailer hitch doesn't make sense for me to make.
If you'd like to do the same as jedmisten, generic hitch plugs are relatively inexpensive and I love to see people come up with new ideas.
jedmisten
Joseph
CA
It’s pretty simple to attach the relocation badge kit to a pre-existing tow hitch cover. I had a circular tow hitch cover that I cut using a Dremel to match the relocation kit size. Drilled some holes and attached it with the correct nut and bolt.
