Backup Camera lines missing after tailgate replacement.
AZ_Liberty
2007 Expedition
Ok, so after 5 months of waiting the body shop finally got a tailgate for the rear-end we had in January.
Body shop replaced the rear tailgate, AND the spare tire carrier.
I assume they failed to do something. Any idea what? Obviously I'm taking it back in the morning, but if it's an easy fix...
I had something similar happen when I installed a spare tire reinforcment and it came back on it’s own after a bit
AZ_Liberty
AZ_Liberty
2007 Expedition
There is actually a setting on or off in Settings. Hopefully that’s all it is.
No, there is not. I dug through all the settings. For some stupid reason Hill Start Assist had turned itself back on, so it was worth going through all the settings.
If you have parking assist, there is a setting to turn off the beep. But no settings for the lines.
Dan-O
Dan
Fountain Hills, AZ
I’ll check it out tomorrow because I turned mine off at one time and they were gone, then got them back. Hope I’m not getting my vehicles confused…New tailgate, new spare carrier with camera I’m assuming.. I think the new cameras require the camera module to be programmed?????
Dan-O
Dan
Fountain Hills, AZ
I checked on mine…..I was wrong, you’re right, I apologize! That feature is on my other vehicle. I’m pretty sure the module needs to be programmed by dealer with the new camera. Hope they get you taken care of quickly.
AZ_Liberty
AZ_Liberty
2007 Expedition
That's my guess. Body shop is 1/8 mile from work, so I'll take it down there first thing in the morning.
AZ_Liberty
AZ_Liberty
2007 Expedition
SOLVED: Body shop needed to use an ODBII scan tool (ADAS) of some sort to initialize the new camera.
