Back up Camera stuck on when in 4L
Kubik603
Oklahoma
‘22 Base Sas
Took the bronco out for a vacation in the mountains. When in 4L the backup camera stays on after being in reverse. 😒 It’s super annoying. Anybody have had this problem?? Anyway to keep it from happening. We have to shut off engine and restart to get it off or I have to reset the infotainment system to get
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
Stuck on? I know when I put mine in 4L the camera auto activates regardless but when I go back to 4H or 2H it reverts to normal.
Kubik603
Kubik603
Oklahoma
‘22 Base Sas
It goes off if shifted out of 4L but we stay in 4L for the trails we were running. Today it eventually went to a blue screen, then solid black and back to the main infotainment. It was a good 10 minutes before it did that. 🤷🏻‍♀️ It was simply annoying so was seeing if it was normal.
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
It may be from not hitting the MPH threshold to turn off the camera. Check the settings to see if the camera needs a certain speed to deactivate
dgorsett
colorado
F250, Mustang, Explorer
Very similar experience. Turning off engine only worked sometimes. Stayed on for a while even in 2h. Intlerestingly the compass was off 180 degrees to. As if it thought I was actually traveling in reverse.. eventually straightened itself out.
mountainbronco
There is a setting that may help, it us called "rear view delay" or something like that, within the reverse sense settings.
Swith the delay OFF.
TheKim
Kim
Not normal. Consider doing a full reset on your head unit.
If issues persist, it's recommended you visit a service center or dealership for repairs.
I ran 4 low for about two hours yesterday while in mud/ruts mode, and it behaved as expected, backup camera only came on while reversing.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning! Could you privately message us your VIN and the name and location of your Ford dealer so I can look into this backup camera concern for you? Thank you!
dgorsett
colorado
OP, If FoMoCo gives you an answer let us know! Seems like when they get involved OP's tend to disappear, meaning problem solved or something nefarious, blink twice if under duress.
Thrash Metash
Howard
Basesquatch
I get this backup camera behavior all the time in 4L. Please update this thread if you or Ford find a solution.
AZshot
Desert Southwest
Vintage Motorcycles, F-150, various other
I also had the backup camera stuck "on" when going forward, in 4L yesterday.
ElBronc
Ryan
WA
Bronco Sport
Same. Camera hung up using 4wd for the first time a couple days ago. I couldn't understand it.
Kubik603
Kubik603
Oklahoma
‘22 Base Sas
Met a guy on the trail yesterday that was broke down, 😳 but he said his camera does the same thing.
kccougar
kc
Southern Utah
A51 Badlands Sasquatch, Z4, Colorado
Mine also does the same. If you shift into reverse the camera activates, but when you are 4-wheeling it may be some time after you shift back to drive before you get up to the speed at which the camera turns off. It is very annoying when you are trying to follow GPS on a trail.
I'm hoping there is a way to manually turn the camera off in those situations. I've resorted to resetting the infotainment system each time that happens, but I wonder if that is somehow bad for the system to be doing that frequently.
Kubik603
Kubik603
Oklahoma
‘22 Base Sas
When I hit 10 mph it goes to the blue screen of death and only sometimes will eventually go back to the main screen. I had the same thought about resetting it frequently too.
