B&O speakers heads up
Lalibertef
Frank
Bunker Hill, West Virginia
22 red pepper OBX 2Dr
Well other than the amp they install for it the speakers are trash.
Replacing them ASAP.
Ford Bronco B&O speakers heads up D9BE817E-5074-4D3B-9292-1ED64B6D1AB2
Ford Bronco B&O speakers heads up 0061E742-1845-428D-BB70-C1A2E2E1EBC7
Ford Bronco B&O speakers heads up 6A0BA293-6261-4951-B7EF-FF0B642595D4
Ford Bronco B&O speakers heads up 99201B8F-3397-4375-BD40-AC8E9CA519FD
mpeugeot
What are you talking about? These are tuned specifically for the optimum sound in the Bronco.
They even used science and the highest quality speakers communism could build.
Lalibertef
Frank
Lol yeah I bought into that on both of the last vehicles I bought with the system😂🤣however the speaker selection is very limited for the sizes. I’m going with a mix of Morel audiofrog and Jbl.
mpeugeot
I went with the Morel 402 Mk II and 602 Mk II speakers - that alone made a huge difference. The rear speaker pods bass cuts about 200 Hz. Just upgrading the speakers made a huge difference in the sound and made it livable.
lawcdav1
Lawrence
Georgia
Did you have to do any modifications? I’m looking at getting a set of Maximo Ultra 402 MKII Coax 4" 2-way
mpeugeot
I had to trim some plastic for the 602's, on the 402's I had to remove 2 mounting tabs off the speakers (they are designed to be trimmed easily). The Maximo Ultra 402 MKII Coax 4" 2-way sound good.
lawcdav1
Lawrence
Georgia
Thanks, I should be getting 4DR non-sas OBX in a few weeks
Lalibertef
Frank
Decided to go with audiofrog GS42 in the dash corners. Morel CDM 700 in center dash. Lower kick I installed JBL stage series 6 1/2 component utilizing the crossover to bring in the low powered by and AMC 2.300. Took the pods out in the rear and installed the JBL UB4000 powered by an ACM 2.300 amp and pulled the sub and replaced with a 300w 8inch Memphis sub powered by the ACM 1.300. Got lots of clear sound that will remain when the top comes off!! All retaining the factory look. The audiocontrol amps hide away perfectly.
