B&O Lux Stereo Tuning?
bytheway
Brice
Louisville, KY
Anyone that’s an audiophile have some settings I can copy from your B&O system to fine tune the stock system as best as possible? I’m sure there’s something better than right down the middle on everything.
MyBHinds
Kansas
1976 Bronco
Depends on the sound you like. I tend to be more bass heavy with good highs. So I put bass at about 3/4 along with highs near the same. Not much in the way of adjustments on this unit which I was really surprised. I also turned on surround sound. Gives a little extra tonal range as the built in DSP takes over. After having a couple months, I ended up adding a JL HO112W6V3 box along with XD600/1V2 and the system really rocks. I can take it out (as it takes up quite a bit of room) when going on trips if I need the cargo space. I also have a cargo enclosure to keep it all secure. And the factory B&O sub is still in place. Loving the way it all sounds now. The W6 is prob overkill, but like I mentioned, I tend to really enjoy the bass so depends on personal preference.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
It would be great if someone could post a very basic, simple break down on what to set the system preferences to, for the various genres of music. Like a simple, Bronco-specific setting breakdown.
604Bronco
British Columbia
www.bronco6g.com
I would think that's quite subjective
For sure, but I’m going to guess someone who’s more into music/sound than I am are going to have good tips vs what I’d do (I.e. - leave it the way it comes from the factory, lol).
Brianstrange
Ma
66 EB , 67 Stang, 77 GMC Motorhome, A6 3.0T, W211
When I get my Bronco, and get some time, I plan on taking frequency measurements from the output side of the tuner \ preamp to determine if they have it set to a curve while everything is set to flat. In my VW TDI I discovered that they "EQ'd" the front channels and left the rears flat. If you swapped outputs by re-pinning front to rear, the system sounded much much better.
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
I also have my bass turned up a little. (This wasn't needed on my F150 with the B&O system)
Also faded the sound to the back one or 2 clicks. (This I think everyone should try it makes a big difference)
Dover
Ben
Hawaii
1966 Bronco Wagon, 2024 Z4 M40i
Can you post a couple of pics with how much room it takes up? I think I would end up doing something similar assuming I can easily take it out when the top is off, or when the extra room is needed like you mentioned. Thanks!
MyBHinds
Kansas
1976 Bronco
Sure. And since doing the upgrade, I have everything set to flat in the audio settings since I adjust the bass with the JL Amp knob.
Ford Bronco B&O Lux Stereo Tuning? 20211212_124028
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
The best way to tune your listening environment, is to put on a track you're really familiar with. Set the volume at medium to medium loud setting, sit back and listen to the track. After at least one listen through, begin to adjust the tone controls until the track sounds the best to you.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
You can use an App that measure frequency such as this one. If my OBX with Lux ever arrives I’ll likely be adding a subwoofer and tweaking the rest of the audio but I don’t know how lacking it is until it arrives. Some would call me an audiophile but I’d classify myself as a pseudo audiophile since I gave up car stereo competitions back in the early 90’s.
Ford Bronco B&O Lux Stereo Tuning? 5FBAD902-206B-4CF2-9706-635D0BC3CE25
mbagne
Placentia, CA
Mach-E GT
That JL is a good sub, I would certainly endorse. However, as another option, JL has an 8 inch sub that most people would find provides PLENTY of extra bass at a fraction of the cost, and is a much better fit w/o taking up so much space. As you say, keep B/O sub in play and there should be enough thump to keep one happy IMO. Part # CP108LG-W3v3.
Any tips for connecting your new amp to the B/O head unit?
Ford Bronco B&O Lux Stereo Tuning? JL 8 inch 2
2022 base
john
AZ 85143
1991 Chevy, 2004 Cooper S
Check here:
Subwoofer & Amp Install in B&O System (OuterBanks/LUX/Sasq/B&O/4dr) - Writeup DIY | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
BroncoZ13
Georgetown, TX
2021 Bronco Badlands 4 Door
Great pic of sub, but even better I’m loving the “NOT JEEP” license plate! 👍😀
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
Exactly the one I'm planning on getting!!
