I came out to the bronco this morning to my lights that are connected to Auxillary 5 being somewhat on (they are baja designs pocket fog lights). They were not at full brightness but were clearly on, even though the aux 5 switch was in off position. When you turn aux 5 switch on, the lights go to full brightness, and then dim with the switch off. On the switch panel the led light is off until the switch is turned on. I haven't used that switch in a month or so and lights were not on yesterday and the car was just parked overnight.
I also have lights on 3 &4 and no issues there. I have an air compressor on 6 and it is functioning properly.
I presume the Aux 5 switch went bad, which dealer should fix under warranty. Any other thoughts or possibilities?
