Auto start stop eliminator
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
I've never driven a vehicle with this feature. Is it really that bad?
IMHO ... no it gets very over exaggerated. My AC still works on those 98 degree days here in Minnesota and I can time the re-start by being aware of my surroundings and easing off the brake pedal without moving forward.
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I wonder if you can wire it to one of the AUX switches!
I already has it's own dedicated switch. It should only be a matter of "jumpering" out the switch. I can't see it being any more complicated than that. Unless there's a weird inhibit associated with it. I would hope not though.
wbrainbow
Bob
New York
1969 C-10, 2022 Black Diamond, 2007 Harley Davidso
Christ! I'm here to forget about work and I see this. AWESOME!! LOL. What industry do you work in?
Retired engineer
  • Like
Reactions: Dom
TheWoo
Manhattan, KS
2021 Gladiator Mojave
I will likely also want to disable this. Never had it in a car but it sounds annoying. That said, i imagine it exists to improve fuel economy at idle. How much might disabling it affect mpg for city driving?
It won't make much difference unless you are in a decent amount of driving with lots of minute+ long stops. What I've seen seems to indicate that until you get to about a minute of engine off time regularly it won't make much difference.
BroncoBuckaroo
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
From what I understand - if you plug something into the 110v outlet Like an LED nightlight ..it will keep the on off start from activating. There should be one right behind the center counsel but I can’t find a pic. I can’t tell if this outlet at the rear is 110v.
Ford Bronco Auto start stop eliminator 7C1D2FF0-0D75-4322-857E-7DB6FFA2B870
Will2497
William
Evansville, IN
2022 Badlands
BlueBronco
DFW
I have one.Dont even thik about it. Push start botton hit the auto on off switch off.done
Exactly. While my F150 doesn't have the ass feature my routine is push to start / and then 2 pushes of the transmission button to select Sport mode. It is all muscle memory now and I don't even think about it.
My Bronco routine will be push to start / ass / (Sport mode, sign, if only the BL had it) / and then flip a few random overhead toggle switches back and forth for the fun of it.
85_Ranger4x4
Iowa
1985 Ford Ranger
I believe that they have this feature because otherwise the vehicle won't reach the minimum fuel efficiency requirement, at least that's what I read on jeep forums.
My slobbering carburated 5.0 will drive for 1/8th mile just on the fuel in the carb bowls... they might hold a cup? I let it run to drain bowls if I have to pull the carb off for anything, I need to time it but it seems to take forever and a day to idle long enough to get that done.
An idling engine doesn't need a whole lot of gas.
I think if in the name of MPG it would take a lot of stoplights to see much of a difference.
Dom
Dom
Phoenix AZ
Retired engineer
What industry? Semiconductor? Congrats on being retired. I still have a long way to go. This bronco will probably set me back 100yrs or so. :LOL:
Toaster
Mars
‘18 JLUR, ‘19 Raptor
its a momentary switch I expect, as is pretty much everything in a car these days, converting it to a static toggle probably wouldnt do the trick. Aftermarket solutions are probably designed to send a pulse when the car starts.
All Ford start/stop switches are all the same in how they work, they are just placed differently and have different sizes. To make it work all you have to do is splice in the little harness and add in your switch that way the second you start the car, it immediately tells the car you’ve pushed the button
wbrainbow
Bob
New York
Telecommunications and networking. I started back when discreet circuitry was used. We used to design computers that would fill a house to do what’s in a smart watch today.
85_Ranger4x4
Iowa
1985 Ford Ranger
when you have 200million cars on the roads, it does add up.
Most of those 200 million don't have this "feature" and a likely significant portion don't use it anyway.
WhoaNelly
Viraj
NorCal
Mini Cooper S, MV Agusta TV800
Given this is all electronics, shouldn't there be an easy way to plug in an OBD-II device like Carly or something else to just disable it? I've seen that app used for activating/deactivating all sorts of little features in other brands. I live in a city with short-ish traffic lights and plenty of stop-go traffic. The auto-start stuff is annoying AF.
TheKim
Kim
It's annoying. My biggest complaint is the AC turns nearly off when it engages too, so it can warm up pretty quick depending on the temperature
Our Honda Odyssey factors this into the climate control and auto shut off.
If it's not cool enough in the cabin (or warm enough during winter), it keeps the engine running. If the engine shuts off long enough at a red light that the cabin is leaving the desired temp, it turns the engine back on and gets the temp back in control.
