EGSquatched
Central Ohio
23 2dr Base Squatch
How is the noise level compared to factory washout floor and carpet? I’ve had both and while I would prefer the washout ability I appreciate the quieter cabin with the carpet.
Devin
2024 Bronco
We love Ken, as a shop owner he really emphasized having a shop do this install.
I did the test installs and would say if you can lift the front seats out, it’s as easy or easier than a Wrangler JLU install.
Having some experience removing interior trim would be a plus, but if you follow instructions and don’t force it together without checking the alignment of the clips, you will be fine.
If any of that deters you, All Pro in Michigan or one of our many other dealers would surely get you setup.
Sounds like we need to collab so you can have a review from a couple that doesn't work in a shop and can show folks how easy it is to install. My Wildtrak would love vinyl floors! ;)
Fordified1
Bob
Mid South Texas
The difference is ours allows better flow to the passive drains, these are separate from the exposed drain plugs on the floors "A" surface, the passive drains are located throughout the sheet metal floor (all models) and are a one way passage for water to escape. With the OEM foam and film pressed against the sheet metal there is less breathing or ability for water to travel down to these.
We chose this carefully during the construction of our floor and feel it is a better option.
Flow to the drains is my concern with the ford washout floor. Just got back from the beach, doors off and a decent amount of sand in the floor. I backed out in the driveway and was about to put a garden hose to the floors but started looking at all the low places that were absolutely not going to drain, so I vacuumed and blew it out instead. Really disappointed in the crappy design.
Fordified1
Bob
Mid South Texas
The insulation we use on Armorlite floors is a polyester fiber, not a cotton. Poly fiber does not absorb moisture like a natural fiber. It is just plastic. The stock floors are foam.
Since you know the location of the passive drains. At what angle should a Bronco be parked to wash out the floors for best flow to those drains? Guessing pointed slightly uphill? Or perfectly level? (Wish it drained like a boat lol)
Armorlite_Kail
Kail
Austin, TX
23 Bronco 4dr WT, 18 JLU Wrangler, 18 JKU Wrangler
To use the main drain plugs, level is best, sightly up or down would also work. Our floor all has a slight draft to the plugs and the reason for our troughs is to capture water together to make it drain easier but also to help it gather so you can give it a swipe or towel if your level conditions are not ideal.
The oem passive drains are located all around the perimeter, it would find its way out at just about any reasonable angle.
ralexander1211
Northern VA
'23 Wildtrak 4dr, '12 911 GTS
Okay I'm sold. Order made. I will try to remember to record & post an installation video when I get around to it.
MtnTopComms
Brandon
Klamath County Oregon
2012 Audi Q5
I received notification that my order was shipping as well.
Looking forward to the install but it will probably be the weekend of the 17th or the 31st as I have other parts to acquire for installation while the stock floor is out...
Bellime
Keith
2022 Ford Bronco
Just got notification that mine is about to ship. Hopefully it will get here with enough time to install before I leave for Montana
