Armadillo Designs Aluminum Hardtop
EasternSierra
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
Forgot to mention that I found a local shop in the Sacramento area that's agreed to receive the top shipment and install the top. That'll be on a time-and-materials basis since it's their first time.
Just waiting for Armadillo now; haven't heard anything for over three weeks since it went to powdercoat. Elapsed time since my order date is now 17 weeks.
Order is squareback 4-door, white.
Got an update on the 17th - my top is going to assembly and quality check.
Lucky Nut
Memphis, TN
97 TJ
At this point, if the MOD MIC top on the bronco was not failing so predictably (my second is showing cracks in less than a year), I would not be interested in this top. I still like the Armadillo top design - other than the water pouring into the cab/ on your head as you exit part others have noted. Yet, it is both not surprising and at the same time disappointing that Armadillo is using the same business model as a year ago with the same results. See here. I was really hoping they would be better.
They do not appear to have "scaled up" as several fans here claimed they would and they have no incentive to do so. Why? Because Armadillo (and their parent/host company) can make money with no risk: people keep ordering these tops and paying their money in advance.
Why is that important, you may ask. Nice folks like @rayofsi and all those before have become unwitting, but not unwilling bankers to and investors In Armadillo. A privilege for which they may only receive the product they ordered and will not get other compensation for the time value of their investment (currently at over 7 months for our friend Ray). To expand on this look up what a 6mo CD would have paid over that time = minimum opportunity cost. Armadillo et al. have transferred 100% of the risk to their customers since they have cash in hand before the the first sheet of aluminum is ordered.
It is a pretty cool trick if you can make it work. However, when the music stops, those without a top may find themselves out of luck or having to pay more to get what they were promised. Expanding lead times are likely not due to the style of top or increasing demand but from issues with production; possibly material availability and probably labor...
rayofsi
Staten Island, NY
Raptor Gen2
Same here! Hopefully not too much longer now.
wishing you guys good luck!, from final assembly to shipping was 2 months for me... But i have the odd feeling that they were trying to fulfill dealer orders and pushing everyone back.. No evidence, just pure speculation. I'm about 6 months from batch start to shipping, 7 months since ordering.
Dtrimpi87
2024 Bronco Badlands Sasquatch
I wouldn't be surprised if it was another decent wait to get through this step. My powder coating stage was just shy of 2 months, but I did get some custom work done. Original order date was July 3rd and got the stage 1 email July 29 so approaching the 4 month mark since my top was started which I guess isn't bad.
Share some photos when you get your top next week!
rayofsi
Staten Island, NY
Raptor Gen2
How do you guys deal with this rubber seal? Everytime I open this happens. .
Pretty happy with the hard top. Asides from all the rain that falls in when I open the door lol
One negative. The 70% tint in the rear. I see everything inside the car. The heater element makes it more work to tint. Sitting comfortably at 9% VLT in the back now.
Ford Bronco Armadillo Designs Aluminum Hardtop 20251203_153535
Ford Bronco Armadillo Designs Aluminum Hardtop 20251127_120520
mangelo
San Francisco
2021 Badsquatch LUX Softtop 4 Door Carbonized Gray
@rayofsi the rubber seal back window is an easy fix, simply hold down hatch back as you close swing gate until swing gate is fully closed, then release. I stand a specific way every time I close back, but the solution works!
NICE looking rig, the top looks sick on your Bronco!!!
mangelope
rayofsi
Staten Island, NY
Raptor Gen2
mangelope
lol i have to stand on the hinge side, close it partially, then come back to latch side to close it..
can't be ideal.
Ninjak
Miami
It will not do that over time. Once the top breaks in, it will not do that. My top did this when I first installed it, then it went away once the rubber started to give more. Now it lies down, and it closes without any issue.
mangelo
San Francisco
can't be ideal.
@rayofsi I thought the same too!
To close while standing on latch side, simply make sure tailgate is open enough, hold window down flush with left hand (keep pressure), close tailgate with your right hand/arm standing far enough away that tailgate goes under your arm. Boom!
Give that a try ;)
rayofsi
Staten Island, NY
Raptor Gen2
had a insulation panel fall off on me. it arrived with the same piece having fallen off in transit.
whats the best method to re-secure insulation panels at the moment?
Dtrimpi87
This is one of my worries. Hopefully it wont become a widespread issue. For the price of these tops it shouldnt even be an issue. I went over all mine and gave them a nice push after install to see if any were loose and I only found one small section a panel that wasnt seated the way it should be.
Earlier in the thread it was posted that the crew at Armadillo was recommending the Gorilla Glue Ultimate Contact Adhesive spray to reattach the panels.
Ford Bronco Armadillo Designs Aluminum Hardtop 730847-1d3d142adec17e5145c5f8228103f97d
Pseudoko
Vince
Chino, CA
My 2 Feet
Gorilla Ultimate Spray Adhesive
https://www.homedepot.com/p/Gorilla-12-2-oz-Contact-Adhesive-Ultimate-Spray-109852/322817576
If it’s the large overhead panel you’ll want to put it on a moving blanket or something. Apply the glue and just stack some books on it. I’d give it some time to cure properly (I left it over night). The smaller panels you just need to hold it in place for maybe 10-15 minutes and you should be good.
Pseudoko
Vince
Chino, CA
My 2 Feet
I should tell Gorilla they should pay me to be their hand model 😂
Dtrimpi87
Finally received my top 12/12 and got it installed the following day. Ordered 7/3 so just over 5 months from order date to delivery.
I dont know if my Bronco is just a bit off, my top was a bit off, or a combo of the 2 but install was a lot harder than it should have been. Had to fight and fight in order for it to sit properly but finally got it. Had some buyers remorse during the install but after it was done and I got to calm down and check things out I love it.
I can definitely tell its much better sealed than my factory hard top. My factory shadow black top didnt have any leaks but had pretty significant wind noise at highway speeds. This Armadillo top is dang near silent. I was pretty surprised at the difference so I can only imagine what it would be like going from a soft top to an Armadillo.
All in all im impressed. As long as the panels coming off wont be a huge ordeal this is Definitely money well spent. Im still waiting on my rear window molle panel. Fabian was able to get all the molle panels powder coated in Velocity Blue for me but the large rear window panel got caught up at the powder coaters for one reason or another. Need to get some better pictures once I get everything dialed in.
Ford Bronco Armadillo Designs Aluminum Hardtop 20251214_102201
Ford Bronco Armadillo Designs Aluminum Hardtop 20251214_102230
Ford Bronco Armadillo Designs Aluminum Hardtop 20251214_103432
Ford Bronco Armadillo Designs Aluminum Hardtop 20251214_102134
Ford Bronco Armadillo Designs Aluminum Hardtop 20251214_102145
Ford Bronco Armadillo Designs Aluminum Hardtop 20251214_102416
Ford Bronco Armadillo Designs Aluminum Hardtop 20251214_102340
