Are the Fox 3.0 worth it?
Shazamalingo
West
2022 OBX SAS
All good points, and compound all of that into the 2k diff in builds, sounds like WT is the better option.
Those were all components I replaced right away with my JLUR and JTR.
I will say this. You are a Jeep owner, so you know. Get what you need for 95% of your driving. If you like an interior a lot more, get that as opposed to something you will use 4x in 5 years. You can spend a ton on these rigs for stuff you will use once and probably didn't need. But, if you are going to go at speed on trails and runs, sure, go for the upgrade/WT.
Shazamalingo
West
2022 OBX SAS
Unless you show me where Ford has this stated it is just BS coming from the dealer.
Happy to have it be BS! He had no incentive to say it (if anything it made me more angry), but he called 2 people in the shop to confirm. Though it's sounding like - from a few on here - these guys are, as I assumed, not on top of it.
Raptor911
Raptor911
Broadlands, VA
it is BS .. many cars that do have a tow package do come with upgraded coolers like the Jeeps BUT if the bronco did it would state it.
one way to check is to see if there are indeed 2 radiators part # listed for the Bronco
Sweetair
Bill
2013 SHO, 03 Marauder, '69 S Code XR7 vert Cougar
The Bronco tow package is the hitch, wiring, and trailer brake controller only. There aren't any cooling upgrades.
Never said the Bronco had these components. Wouldn't be surprised if there were minor differences in components though when comparing both the tow and non tow.
Believe that my 2008 Expedition Eddie Bauer with the tow package I traded for my current 2021 Stealth Limited expedition with tow both came with those items to assist with the added strain and heat transfer that is generated when towing. I am glad when I towed my 1969 Cougar XR7 to Detroit in 2017 in a 26' enclosed trailer came factory equipped with the the tow package.
vrtical
Doug AI
GSMNP, TN
Fords
Dealer said there is a difference in the radiator and trans cooler. He specifically said, "do not throw anything heavy on a trailer and pull it with an aftermarket tow." But, hey, these guys weren't exactly on top of their game.
Dealer said....
Ford Bronco Are the Fox 3.0 worth it? Fimages%2Fa9454218eb75d232fa793a84857e00d5%2Ftenor
cmb396
cmb396
chad
WV
JLUR, JTR
Well said. Bronco thing is new to me, always been a Jeep guy.
One thing I’ve learned with owning Jeeps, is the rubicons always hold value very well. Hence, looking at WT.
I’ve used the lockers, etc on Jeeps plenty of times. Have i been able to go anywhere my non rubicon friends have, nope, just maybe a little easier.
One thing I always look at buying a vehicle like this, is potential resale value down the road.
I won’t need the Hoss 3.0 fox 2.5s, upgraded steering and control arms are def nice imo. Lockers, another nice feature.
so much new to stuff to learn with things!! Lol
CeeCeeBronco
CeeCee
Houston
I ABSOLUTELY would be surprised if there were any differences in the components. There's never been any indication of different components at all.
EDIT: If you look at this, you will see that any idea that the components are different in the Broncos with the tow package is complete hogwash. Page 2 specifically points out what components the tow package adds - it's limited to the harness and connector, the trailer module, and the hitch receiver. I have no idea where false ideas like these originate and spread, but I guess it's the age we live in.
https://www.ford.com/cmslibs/conten...des/2022_Ford_Bronco_Towing_Info_r1_Mar30.pdf
pequigah
Adam
Jeep Wrangler/Ford F-150/Ford Explorer Sport
@Silver-Bolt Trailer Brake Controller? Are you sure about that? My towing package only came with the hitch and wiring harnesses. Pictures?
CeeCeeBronco
CeeCee
Houston
The Ford Build A Bronco page specifically says that the Towing Capability package "Does not include Trailer Brake Controller."
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Basically have 2 4dr builds narrowed down, OBX Sas, or Wildtrac sas. Both with same options, the obx is 2k less and does not have the Fox 3.0. Will be mostly a road warrior, maybe some light off roading.
I have Fox 2.0 on my JTR, they ride nice, slightly too plush for me, and on 39's, I feel they have too much body roll on the interstate.
I do not need the Fox 3.0 and what they are designed for, but I believe the option alone is over 3k, but the difference in the builds is right at 2k or less, and I know you could not buy 3.0's F and R for that.
Curious on yalls thoughts? Thanks.
Just get the Wildtrak Hoss 3.0. Nothing better than having a factory warranty on expensive parts like these.
Silver-Bolt
Bill
Eureka, MT
I am not positive on the controller. I have read on hear that some have it. Mine hasn't been built so I don't know first hand.
vrtical
Doug AI
GSMNP, TN
Fords
When you get the tow package you get wiring harness under the dash to plug n play a brake controller but the controller itself is not provided. If you don't get the tow package you lose all the supporting wiring. The work around is do aftermarket Curt kit with Bluetooth controller
