Are 2 Door and 4 door Subwoofer Boxes the Same?
VAtruck
Title says it all. I may be able to get a free 4 door box/amp/speaker assembly (7 speaker system, not B&O). Figured it would be a cheaper way to improve the sound in my 2 door 2022 with the base 6 speaker system for the cost of some wire and a little labor if it will fit.
Squatch
If you mean the stock subwoofer enclosure behind the panels? I believe so, but there are a few threads on the subwoofer enclosure on here. You should search those (upper right corner magnifying glass) to double check, though.
VAtruck
VAtruck
The box specifically (Didn't see mention of interchangeability in any of the subwoofer discussions). The amp and speaker will be fine. I don't want to go to all the trouble of tearing out the trim panel to find out the box won' fit.
VAtruck
VAtruck
Well, I never got a reply so I went ahead and took my truck apart to check. Not only did the box fit fine, the 2022 had mounting studs and cutouts for panels nuts for the box. I guess Ford was already planning for the future subwoofer option.
