If i remove the washers from the shiny bolts assembling the black brackets and replace with what I had leftover, those are larger inner diameter washers (seems an odd fit). And I’m now missing 1you have everything you need already assembled on the two long bolts. packers are washer like and are metal.![]()
Should the longer bolts get 2 large washers as shown in pic below, cuz the diagram in ARB manual only shows 1? If I place in location and brackets parallel, those packer washers don’t fill the gaps
Still unsure where those medium size black washers go??
