- Curtis
- Mar 21, 2021
- 44
- 1,893
- 9,813
- Silverdale, WA
- G2 Raptor, GT350, Land Rover SERIES and DEFENDER
- First Edition
AR | STIRRUP®
The BRONCO community asked for it and we went to work! After reviewing what was shared from last year's SEMA Bronco, there was plenty of room for improvement, both in design and function.
Made from a sizeable chunk of 6061 billet, the STIRRUP is very beefy part and it will look right at home on an overland build, trail conquering rig, or your daily driver. It's five inches of width will give your boot or shoe a proper platform to assist you in climbing up in the saddle. The entire part is coated in RAL 9011 Graphite Black, then post machined to remove the coating from the top surface and reveal the raw billet aluminum and provide a very classy contrast. This will also give the STIRRUP years and years of rugged good looks. The more you step on the the more naturally worn the aluminum will look but it won't affect the Graphite Black coating.
The STIRRUP is mounted to your OEM rocker rail with M8 and M10 316 stainless fasteners. A single M8 bolt alone has 110,000 PSI tensile strength! The STIRRUP is definitely more solid than the rail it's mounted to. With its coating and the use of aluminum and stainless, the STIRRUP will require little maintenance and it will last the life of your Bronco.
The STIRRUP will be sold in pairs. This will also be a BRONCO6G exclusive part, at launch, and B6G members will always be eligible for the 20% discount. We're going to handle the purchasing a little differently this time....
AR | STIRRUP Clamp Bracket
Renders are below. The Clamp Bracket is standard. Both the 2" drop location and standard height (more even with the top of the OEM slider, are available on the Clamp Bracket.
Pricing:
Retail price for the AR | STIRRUP is $494.43
BRONCO6G members are eligible for a 20% discount, making the price per pair: $395.55
NOW TO THE FUN PART:
If you would like to pre-order your STIRRUP pair or set of four now, here's what you'll need to do.
1. Reply in this thread: SEND IT!
2. We will PM you with a one time use code for the ARCHETYPE RACING website.
3. Go to the link, also provided in the PM, to the STIRRUP, and you'll be able to check out with the BRONCO6G 20% discount.
4. Spam F5 on the tracking link, once you have it, while you're waiting for your STIRRUPS to arrive.
Both solid black and decked are in stock and ready to ship!
Pricing:
