- Brian
- Sep 14, 2023
- 65
- 9,026
- 16,127
- Central CA
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Big Bend
16GA is probably fine up to about 50W, I'd recommend just running 14GA (it's very common and shouldn't be much more expensive) if you are running new wire though, 12GA wouldn't be unheard of, but probably overkill for your situation. Speaker wire / ampacity is a bit different than just regular power wiring - if you are wiring a light or a winch or something and the wiring causes a voltage drop of 0.1 V, it's not a big deal. On a speaker, it's a huge deal.I was going to order a wiring kit on Amazon that has 16 awg wire. Is that sufficient? Also, will buying better speaker wire actually make a difference? There’s a ton of kits around the $20-50 dollar range, although that seems like it would work I really want to do this right one more time. I wasn’t very happy with the kicker key 200.4 so here we are lol
I do think @Area51BS is correct in staying away from CCA (Copper Clad Aluminum) - go 100% copper stranded (not solid - you often see solid for home wiring) and you'll do ok. I wouldn't pay more for oxygen free (which is OFC) or any brand name or anything - 100% copper and thicker gauge is what you really want. Stranded, thicker wire will give you cleaner signal - bar none. You don't need anything special for automotive vs home audio either - any generic speaker wire will do ok
