Anyone Running the Ford Performance Shocks
TXDOZER
Les
El Paso TX
2022 Bronco Basesquatch & 2020 Escalade
Looks like Bilstein 2.65” Diameter shocks (bigger than Raptor) with Sasquatch springs.
Ford Bronco Anyone Running the Ford Performance Shocks IMG_3380
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
These are non-adjustable Bilstein 6100s. There are a few that are running them and many more that have the adjustable 6100s. Search the Suspension sub-forum. Your post is in the Raptor sub-forum and isn't pertinent to Raptors.
MileHighCitizen
Al
Denver
Bronco 2D 2.7
I have the 6112's on my Badlands; same shock but adjustable, different springs.. They are much firmer than OEM, but not uncomfortable or anything. I run them on the lowest setting and got about a 1.5-2" lift over factory Badlands.
TXDOZER
TXDOZER
Les
El Paso TX
Thanks! Sorry for getting on the wrong forum.
Ford says these are 2.65”. The 6112 is 60mm, which converts to 2.36”.
headed over to the correct forum now.
Robs
New hampshire
2023 Black Diamond
I installed them on my non sas black diamond. Frankly I did t see much if any improvement t on road or on the trail and I didn’t get the full 2” lift as advertised. they are much bigger diameter than OEM so I suppose they will do a better job if on longer washboard trails
Red2000
2022 Bronco
Have been running them on my 2 door for about 10,000 miles now.
TXDOZER
TXDOZER
Les
El Paso TX
How are they doing? I need to upgrade my 2Dr Sasquatch for a Baja run later this year. Need to get to 2.5” plus. The Bilstein recall slowed me down a bit and I ran across the Ford Performance shocks.
HoosierDaddy
__ Eric
NW. Indiana
Interesting question, I'm not sure these provide any lift over Squatch or if they even do make a Squatch version.
Never mind... i just googled that shit.
2dr version states the same.
Ford Bronco Anyone Running the Ford Performance Shocks 1000008008
Bilstein
Poway
2023 Bronco
2.6" Outer Diameter, 60mm piston
TXDOZER
TXDOZER
Les
El Paso TX
Got it. Thanks!
Any idea what the replacement is going to be for the recalled Sasquatch Bilsteins?
Bilstein
Poway
2023 Bronco
Got it. Thanks!
Yes, Ford has been installing them since July on new builds. The reservoir mounting flange is much shorter.
