Anyone replace Shift Knob yet?
RallyGorgo
George
Spencerport, NY
2023 Ford Bronco Badlands
Hey, has anyone else noticed something in the shifter mechanism wearing a hole through the shift boot? If I’m looking down at the shifter it’s happening at about the 8:00 position (12:00 points at the front of the Bronco). I’ve only got 3,500 miles on it and the hole’s ~1/8” in diameter. I’d take it to a dealer but expect they’ll tell me I’d need to leave it for a few weeks…
Anyone else see this?
HolidayDog
Everglades
MT
24 Everglades
Everglades
Not a Bronco but still a Star Wars fan.
This is aluminum and does get hot in the summer and cold in the winter but the trade off is worth it to me. It’s not untouchable.
Is it possible to swap knobs in the Automatic or only the Manual?
Ford Bronco Anyone replace Shift Knob yet? IMG_6250
jsoa
Jose
Delaware
2024 Bronco 4dr
I also ordered the cue balls, looks amazing, however I did notice that after installing it, my finger does rub up against the locking nut, which doesn't feel all that good. Has anyone had a similar experience? Perhaps wrapping it with something would help.
Calypso
Don
Charlotte, NC
'23 Bronco Heritage
Just got my Twisted Shifter... messing around using a screw driver to pop the cap off and it's not working... how'd you do yours?
Late to the party as usual, butter knives at 3 and 9 o'clock worked well for me. Carefully insert each blade under the cap and pry up, one knife in each hand.
Ford Bronco Anyone replace Shift Knob yet? 1708916506570
jsoa
Jose
Delaware
2024 Bronco 4dr
twisted shifterz was kind enough to send me a new adapter, as I had issues with the one I got. Its been updated to no longer need the set screw, and its slightly shorter. Fits real snug now.
Ford Bronco Anyone replace Shift Knob yet? PXL_20240329_010107975
Ford Bronco Anyone replace Shift Knob yet? PXL_20240329_010439211
Ford Bronco Anyone replace Shift Knob yet? PXL_20240329_010011277
Dlrsavannah
Savannah GA
21 Bronco
Yep, I notice it as well. I bought the white knob with the grill patern and love it but the adpter on mine has too much play on the stick. Screw is down tight but the adapter moves a little so I just removed it altogether. I think I'll see if they can send another.
jsoa
Jose
Delaware
2024 Bronco 4dr
contact them, they sent me a replacement adapter which doesn't have the set screw, see my post above
Dlrsavannah
Savannah GA
21 Bronco
I just sent them an email describing the problem. Mine didnt have a set screw either but I can see the fitment on the stick isnt right since it moves around slightly when installed and screwed down. Thanks!
coffeetwitch
kansas city
bronco
has anyone installed the twisted shifterz v2 adapter and knob? im curious how it installs vs the v1.
thanks
CarmeloS
Carmelo
Central Jersey
If I could get a boomba off, Id swap my shiftboot and also get a color matched knob
coffeetwitch
kansas city
bronco
i had to use a wrench and hammer, slide the wrench under the ball with the open end and hammer it up.
