Anyone Removed / Accessed the Window Switches?
John P.
Orange County, CA
BMW X5
Would like to mount my Audiotec Fischer Conductor audio remote here, if possible. Not sure that I’m interested in removing the seats and entire console to do this, though.
Curious if this part can be removed from the front/outside, versus the rear?
Thanks.
Ford Bronco Anyone Removed / Accessed the Window Switches? 0909FFFD-D41A-4ABE-A4C9-1B37A9CCDE49
Ford Bronco Anyone Removed / Accessed the Window Switches? B1D71BF4-697E-47F8-81D3-51FBCF4F89ED
smiths65
Niskayuna, NY 12309
'21 RAM1500 BigHorn
Ford makes a trailer break module, center console gets modified in directions...space closer to drivers seat is used for button locator. Forget the VM2DZ number...check the accessories offical page
smiths65
Niskayuna, NY 12309
'21 RAM1500 BigHorn
VM2DZ2C006A
Brake module, look up the install documentation
John P.
John P.
Orange County, CA
BMW X5
That’s a good option. Thought about that side, too. Thanks for the idea.
Found a video on point:
gringoloco
Alabama
2023 2-Door
Thanks.
@John P. I removed this switch panel today to test if the Conductor will fit. I am happy to report that installing it here will only affect the trim panel and not require any modification of the switch mechanism itself. There is almost 22mm of space behind the trim panel and the Conductor housing is only 17mm deep.
Pictures show a Mockup with dimensionally-correct 3D printed stand-ins, since I don’t have the Conductor yet in hand. The trim piece pries out from the front nice and easy with a slim trim tool. No console or seat removal required.
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0255
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0251
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0248
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0249
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0246
gringoloco
Alabama
2023 2-Door
…and a couple of “installed” pictures that show what it would look like in the cabin:
@flip Are you able to pull the part number for the 2-door window switch bezel? My Google-fu is failing me. If we go poking holes in these, it will be nice to have a replacement on hand. Thanks in advance.
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0265
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0261
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0262
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_0258
John P.
John P.
Orange County, CA
BMW X5
Incredible! Thanks for posting this. How did you remove the switch panel from the console—does it just pull out?
Roger123
Roger
VA Beach, VA
From his post above:
gringoloco
Alabama
2023 2-Door
John P.
John P.
Orange County, CA
BMW X5
Perfect—thanks!
John P.
John P.
Orange County, CA
BMW X5
Can (finally) confirm it fits!
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_9466
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_9468
Ford Bronco Anyone Removed / Accessed the Window Switches? IMG_9469
