Anyone planning to install two way radio (either Ham, CB or other?)
Deputy909
George
Peoria, AZ
2015 F150, 2013 Traverse, 2007 Mustang Conv.
Is anyone planning to install a two way radio, either Ham, CB or other? If so where are you thinking of mounting it? What is your plan for an antenna?
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
I will be. Rugged radios to match the race car.
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'75 Intl D150/'22 Badlands
I saw on one of the concept or test mules where they mounted a (presumably) Ham antenna on the front fender limb riser hook, seems like a viable spot. CB antennas are typically larger so I don't think that location would work. Aftermarket will probably come up with a mount on the spare tire or rear bumper like whats available for Jeeps.
There are so many different radio configurations, it's hard to say what works best.
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
I'd like to make use of the trail sights for antenna mounts. As for what I'm mounting, I'm definitely going to be mounting my Yaesu FTM-400DR. At this point, I'm thinking the base will probably go in the under floor storage at the back and I'll run the screen up to the front dash somewhere.
Then, I'm thinking about running an antenna lead into the truck where I can swap it between GMRS and CB. I don't care enough about either of those to hard mount a radio but I run into people who have one or the other often enough to want both options. I believe, as long as I can swap both radio and antenna, the lead wire doesn't matter. You can get both cb and gmrs antennas in nmo.
Hopeless Diamond
JR
Chumstick, WA
Yeah, running the antenna lead(s) into the cabin is gonna be the biggest thing. I would think if/when they have the dash accessory rail available, that would be a great place to mount a remote head and even remote speaker (I run a Kenwood D710, have one band out of the base unit, the other out of the remote speaker to help figure who's talking)
AcesandEights
Ace!
Oregon
DR650
Midland MXT400.
smrpilot
PNW
'15 Silverado 3500HD, '68 FJ40
I'm thinking at this point, I'm going with both 75-822 CB and the MTX-275 GMRS that hides away in the center console when not in use.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Just get a programmable tri-band radio and a broad band loaded antenna and you can have it all in one unit. I never use CB any longer, FRS,GMRS, 2mtr ham, or packet radio.
Coldsmoke
Knuckles
Northern Illinois
Ford F150 Lariat
Going for a compact CB, most likely this self contained Cobra so I don't need to worry about mounting a head unit in a visible location.
Ford Bronco Anyone planning to install two way radio (either Ham, CB or other?) 1614272088844
Apples
Nick
I already own the HAM radio. And the price premium on tri-band radios is more than the cost of buying a couple cheap handhelds and running the antenna wire.
BEM-S4
Philadelphia
BMWs & Porsches
I ran that unit on my Cannonball drive. It worked fine. We didn’t hear anything interesting but the unit itself was easy to install and worked as advertised.
JesseS
Jesse
Northern California
I was running CB back in the 60's, talking skip on a Cobra 14 ch and a 200 watt amp from my GTO, but CB is pretty much dead, even the truckers have moved on. Why try to use static prone short range AM or sideband when there is FRS & GMRS FM, or HAM if you have a ticket.
PWillette
Parrie
Maine
I'm using a hand-held GMRS these days. The dash mounting rail would be perfect.
ResidualGenius
Zach
Denver
Kenwood dual-band with remote head on rail (hopefully) and antenna on rack?? possibly on trail sight
