Anyone make Plastic Bed Rail Caps?
Rough Rider
2018 Mustang Convertible
They should be able to attach at the three bolts per side for the roofs since you wont use them as the same time as a roof...
Gtrekker
Gary
NJ
Does anyone make a set of plastic bed rail caps yet? I've searched and found none. Seems it would be a short kick for someone like @Mabett or @Xipex or someone like that.
I love running with the top off but those un-covered bed rails are both a cosmetic and functional problem. Yeah they look bad, but I've also found that when I have the top off, I tend to load stuff into the back seats over the bedside, stuff like my backpack and other items that have the potential to scratch the paint if I'm not careful. The bed rail cap would function as a scuff guard.
I'm guessing plastic would work best and be most economical. Make it match the other plastic parts like the fender flares, door handles etc. I would make it heavy-duty enough to step or walk on, for those of us who like to climb all over our Broncos. Maybe even have a grip pattern on it rather than just a smooth top. Make it so that it simply snaps into the hard top bolt holes and is easy to pry off when its time to put the hard top back on.
Please do them for 2-door first :)
Should be a simple thing for Mabett to do and have a good turn-around time for them. Forward your suggestion to him.
Dusty
Dusty
Mentone, CA
70, 71 & '21 Broncos
They were already tagged in the first post.
BWepps
Huntley, IL USA
2022 Ford Bronco Outer Banks
I'm in for a set.
Dusty
Dusty
Mentone, CA
Are there any updates on this from anyone?
Nope. Seems like it would be a no-brainer especially for these Chinese companies churning out all sorts of plastic doo-dads for the Bronco. But apparently they're just not interested. Unfortunately it's probably going to a require an American company to invest in tooling up for it to prove the marketability. Then the Chinese companies will swoop in and copy it LOL.
ChrisB351
Shreveport, LA
One of those items I never knew I needed until someone else mentioned. I like the idea.
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
Ford Bronco Anyone make Plastic Bed Rail Caps? IMG_3034
Would definitely be interested in a cover using the same mounting points.
Edit: Maybe @EIGHTLUG AR could do an aluminum one even?
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I agree, anyone who ever takes off their top would eventually want a set. Seems like a no brainer, to the point you would have thought Ford would be making these an option when you buy your Bronco, more useful then some of those other options on the Build & Price.
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
Hard to guess. I think it's going to be one of those things that most Bronco owners don't even realize they need it until they see it, then they say hell yes I need that. The potential market is everyone who takes the top off. No clue how many that is. But I think it's probably as good or better than for a lot of the plastic accessories I see companies like yours making. I would bet that some of the big-name bed rail cap companies will eventually do it...Westin, DeeZee, Bushwacker, etc., but whoever is first-to-market will own it.
I'm in......Two door unit please.
Bruzer22
CO
1968 Mustang, 2022 Bronco
Only downside I can see is vibrations and the cap wearing through the paint. I've seen that on more than a couple of pickups, especially at the rear bed corners.
Dusty
Dusty
Mentone, CA
Not if its designed right. The bed rail on the Bronco is already designed to have a heavy hard top sitting on it. The top sits on that raised bump-up area, not on the outer edge where it curves down to the bodyside. As long as the bed rail cap follows that same contact patch and isn't too flimsy, it will be fine.
Bruzer22
CO
The pictures of the pickup caps wrap the rails. If a Bronco cap doesn't wrap over the body panel and rests like the hardtop, then yes, I agree.
