Does anyone make a Bronco Catalytic converter cage?
Rush4th
Donny
Norco, ca
2021 bronco
The transmission skid. In the description it says it protects the cats. There was a post about it on here too. Regardless, I need belly protection anyways.
ROKBRNC
NorCal
2004 LJ on tons, 1970 Bronco, 2019 Tacoma TRD, 2022 Audi SQ5
Best way to protect your cats or anything else of value is to move to the country and use a .45 to deter anybody from coming onto your property…pretty simple and low cost really 🤷‍♂️
Lt. Ron
Lt. Ron
CT
1973 Bronco 1986 flareside, 2015 F-150
Not helpful or realistic unfortunately
Rush4th
Donny
Norco, ca
2021 bronco
So I didn't get to install the transmission plate, but I did mock it up really quick. I didn't get to install it cuz I have the stock engine bash plate and it doesn't work with the jcr transmission plate so I'll have to get the engine skid. The bolts are too short. I might get longer bolts and run it s a safety measure, but the plate will sit too low if I did that.
Anyways, the plate covers the cats enough to make it a real bi*ch to be able to cut them off. Would definitely work as a for security.
