The JL W1 is a single voice coil vs the Kicker which is a dual voice coil. So, the JL will run at 4ohm whereas the Kicker was running at 2ohm wired in parallel. My amp will send 150w @ 4ohm vs 300w @ 4ohm. I’m interested to see what the JL will sound like with it running on 150w vs 300w with the Kicker.Perfect thank you so much that is what I was wondering, I have a chance for the w3 for the price of the w1. I was following the other post and it gave me the confidence to try this, replaced all the speakers except the sub.
The Kicker has vents on the back of the magnet. I think that the sub over heated because there was not enough depth to allow it to vent properly. The JL W1 does not have the venting holes in the magnet, so it should be better suited in the enclosure.
