Will JL Audio XD700/5v2 fit in the 2023 ford bronco subwoofer enclosure ?
mandark
Manish
Texas, USA
Ford bronco 2023
Will JL Audio XD700/5v2 fit in the 2023 ford bronco subwoofer enclosure with like some additional backboard or something? Will the panel close properly? The dimension of the amp is : 10-1/4" L x 7-1/8" W x 2" H.
Thanks in advance.
jayr1959
Jay
Delaware
2015 Jeep JK 2DR 2008 Saturn Sky Redline
I don't think it will fit. I tried mounting my Musway 8.6 x 5.9 x 1.7 on a 1.2" backboard and the panel would not fit. The cupholder section is set in pretty deep. Below is what the mounted amp looked like.
35tires
'23 Bronco, '21 4Runner
No. Not at all. I have it in my 4 door.
I had to put it on the driver's side under the panel. If I had a tow package it wouldn't have fit, but it worked fine, albeit super, super tight.
What are you running for a sub for that 5 channel, a tailgate sub?
mandark
Manish
Texas, USA
Ford bronco 2023
Not using a tailgate sub. Wanted to do something similar to what @jayr1959 mentioned above. Where did u fit it in driver side panel? how does tow package make it not fit? Lastly, how do u like the sound? Did u use it with or without dsp?
35tires
I put it against the back side behind the wheel well almost against the 'wall' where the tailgate opens. there is a cubby like space in there. Had to do some fab to secure it and run the wires nicely. It's a VERY tight fit and I would look for an alternate place if I did it again but I was already in for a penny so...
The tow package has a module that is inside that same open space. Without it we benefit.
It's hard to determine sound for me, but it's fine for I have. If I had to do it again I'd have kept my original amp, the audiocontrol 650.5 marine. Very close in spec and about half the price.
mandark
Manish
Texas, USA
Ford bronco 2023
Ah i have a tow package and its a no go for me there then. Wonder if the sub enclosure for b&o will have more depth since it has a bigger amp. Thinking that may make a diff. Otherwise, probably move the sub to tailgate which i really dont want to do. Heh
mandark
Manish
Texas, USA
Ford bronco 2023
Ford Bronco Will JL Audio XD700/5v2 fit in the 2023 ford bronco subwoofer enclosure ? IMG_1742
Btw, did u try it vertically as well? I m assuming that doesn’t work either
jayr1959
Jay
Delaware
mandark
Manish
Texas, USA
Ford bronco 2023
Anyone know if the amp will fit if i purchase a B&O sub enclosure?
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
I have a JL HD900/5 and audio control LC7i mounted to a board in the stock sub location. Had to angle the amp to clear the panel and not pinch the wires. Required moving it a few times to get it right but it fit eventually.
JeffL
Massachusetts
2019 Challenger Hellcat Redeye / 2023 Base SAS
with the sub out there is a bunch of space in there. i have a 5 channel alpine amp and lc6i in there:
for reference according to alpine the dimensions of just the amp are:
  • 11.4375"W x 2.125"H x 7.5"D
Ford Bronco Will JL Audio XD700/5v2 fit in the 2023 ford bronco subwoofer enclosure ? 1711643167826-s5
mandark
Manish
Texas, USA
Ford bronco 2023
@ChrisB351 & @JeffL thank you. However, i want to add the sub in the enclosure as well if possible.
ChrisB351
Shreveport, LA
My board was made to mount vertical. This would make it so much easier. Guess Im off to the hardware store to get some L brackets I can bend.
JeffL
Massachusetts
i'd bet you can still get the amp in there. ive since added another sub amp and another 10" JL as the 1 just wasn't doing it. i have a 2 door so my luggage space is now just the back seat.
