Anyone else accidentally turning on headlights?
Moto26
Tucson AZ
6'10"
I think I hit it once in the last 15 months?
See, at 6’ 10” you’ve surely had to condition yourself to get in and out of vehicles in a different way than most people, so you already have the muscle memory to avoid hitting that knob. 😎
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Yes, Ford design flaw. I just check the knob every time I exit the Bronc. Just added to the to-do-list after I park it, turn off the ignition, put in second gear, pull up the e-brake, etc. You get the picture. Some define me as anal, or whatever disorder term is currently used to describe this behavior by the medical community today. I define it as normal which use to mean responsible back in the day. Tommy Bronc
God, we have another broken one or maybe it was a design flaw...anyways, can you try and do better please!
Combustion_King
Derek
MA
Yes
I've never done it, 2 door. 5"11. I could see how one could though.
thatspecialbeat
Ryan
Meridian ID
Subies
Nothing to do with height or hitting the knob. There is a known issue with the lights. They will just turn on by themselves and then off after a few minutes. It will sometimes be on "on" instead of auto when you get out so it dings. But it will often just do it on its own.
EDIT: Apparently you can go get it fixed.
Ford Bronco Anyone else accidentally turning on headlights? ALLOFTHELIGHTS
Ninjak
Miami
6'-4.5" never had an issue once? Lights stay on auto all the time. It is a set and forget in my vehicles.
sjjohnny
El Paso
'22 Bronco Black Diamond, '00 Tacoma
Yup, occasionally happens, and the chime tells me when it does. I'm 6'2"
Moto26
Tucson AZ
Be that as it may, that is a separate issue. Hitting the knob with your knee is a real thing that many of us have (obviously) experienced…
thatspecialbeat
Ryan
Meridian ID
Subies
Be that as it may, that is a separate issue. Hitting the knob with you knee is a real thing that many of us have (obviously) experienced…
Well yeah, but that isn't turning it on by itself with nobody in it. If the problem is really just hitting it with your knee, solution is don't hit it with your knee.
I am 6'2" and thought I was hitting it with my knee for months until I made sure not to do it and thought I was crazy until I found out about the knob issue.
wigglysqiggly
William
2023 Ford Bronco
I wish there was a way to leave the setting on off rather than auto. Auto tends to turn on and off depending on lighting which can dim the dash or change lighting
AZ_Liberty
2007 Expedition
It's been a common complaint. Switch is in a stupidly low position.
PSUTE
Western Maryland
Sierra
This. Had my switch replaced, end of problem...
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
I think its actually both. Just last night I had what you posted happen, I got out and there was a glitch like scenario where I know I didn't hit anything but the lights were ON. Other times I have 100% grazed the underside of the knob with the top of my knee.
Is there enough room to tuck a thin cowl like shield to the underside, maybe an aftermarket trim piece type deal?
MayhemMike
Mercury
It does happen but that’s why the headlight on alarm ding sounds as you exit the vehicle. The ding is a polite way of saying ”. Hey fool you left the headlights on”.
