Another DIY Cheap Mudflap Install
Weasel2021
Sean
South Carolina
Bronco Badlands and Bronco Sport Badlands
Fab’d these up to get me by until Rokblokz starts shipping. I doubled up some cheap RallyArmor ($25) flaps with a bent piece of 2" aluminum and rivets. Working well so far.
Ford Bronco Another DIY Cheap Mudflap Install mudflap_1
Ford Bronco Another DIY Cheap Mudflap Install mudflap_2
Weasel2021
Weasel2021
Sean
South Carolina
Those actually look pretty dang good.
Thanks. I'm still running them. They've been dragged through everything. No issues and no rock chips on the doors. At the time there were zero aftermarket options.
RallyGorgo
George
Spencerport, NY
2023 Ford Bronco Badlands
I made a set for my Jeep, used a rubber mat from Runnings (probably also available from tractor supply stores), is the rubber mat that gets attached to the inside of pickup truck tailgates, worked good enough that I’m going to make a set for my BL. The rears are removable, the base is bolted to the frame and the tube & flap can be removed by pulling out a 1/4” hitch pin.
Ford Bronco Another DIY Cheap Mudflap Install IMG_5063
