Amp suggestions after speaker upgrade
Area51BS
Ron
Badlands non SAS 4dr 2.3
I would get enough channels to do what you have now and a sub. Along with minimum of 2ch pre outputs for future expansion. Maybe 4 preouts. Example 6 ch plus 2 for sub now(8). But if you wanted a larger sub amp later and you could use the current sub channels to go full active on the dash mid/tweets and preouts to a sub amp. Basically only buy something that can get you to 10ch minimum and you will be set and not waste money.
wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
So I have purchased replacement speakers for my 2022 base 2 door bronco. Hertz CX 100 for dash and rears (probably unnecessary) and Hertz CX 165 for kick panels.
I went down the Kicker 200.4 rabbit hole and I've read more threads in the past 3 days than I cared to. Believe me, I HAVE used the search function - more than 100 times.
I do not want to do the kicker 200.4, as I'm concerned about the dash and kick panel speakers being wired together creating a 2 ohm issue for the kicker 200.4. So that's out, along with having to order some rare head unit harness. I don't mind spending money on a good amp or separating the dash and kick speakers.
I am not adding a sub or sub amp at this time - that's for later.
I went to two different audio shops and both recommended a LOC or similar device between the head and the amp to adjust the line out from the head unit. Past here, I am lost and need some help.
I don't mind running new speaker wire to separate the dash from the kick panels.
I just want an amp that will drive the speakers to get a bit more clarity and volume. Gosh, I listen to podcasts most frequently but I have older ears.
Before anyone posts "use the search function", I just want to say, I have, and I've read probably 2,000 posts/several 30+ page threads and still am no closer to arriving at a good solution that I understand.
I'm not an audiophile, and heck, listen to podcasts most often when on the weekly 4 hour trek I take to my job. So just want a bit more volume and much better voicing.
The AudioControl D4-800 will do everything you want it to in one box. Crutchfield has it for $699 right now.
P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
If you decide to go the Kicker 200.4 way, let me know if you have any questions. I was able to get everything setup and dialed in very easily in less than 2 hours. It's been a joy to get in and crank my tunes. 200W Front sound stage with the rear pods on head unit power. Excellent bang for your buck.
