I mounted the front plate to the bumperette plastic part.
- It covers the right D-ring
- It is drilled and screwed into plastic
- The bumperette mounts with clips so pulls off for easy access to D-ring. Negative is it is also easy to steal.
- Bumperette easily replaced if you want to change or eliminate front plate. Part is m2db-17e810-ab
- Mount is from Amazon:
https://www.amazon.com/dp/B00032K4VA?psc=1&ref=ppx_yo2ov_dt_b_product_details
