Alternate Fog Pocket Solution Installed
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Not sure if these exist - but looks like 2 pods of 1x3's would fit that space perfectly.
You could certainly do that. Our kits are not setup that way (1x SS3 & 2x SSC2 or 2x SS3 & 1x SSC2) but you could certainly buy our brackets w/harness and then 3x pairs of SSC2.
The reason is simple... WAY too many options then and it honestly gets really confusing for customers. Plus we like to fit as big of lights in there as we can.
But we also allow customers to just buy the brackets and harness and lights all "ala carte"
Complete Kits are here: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
or
Brackets w/Harness Option: https://www.4x4truckleds.com/kr-off-road-triple-fog-light-brackets-for-2021-ford-bronco/
Diode Dynamics Lights: https://www.4x4truckleds.com/led-auxiliary-lights/diode-dynamics/
Baja Designs Lights: https://www.4x4truckleds.com/led-driving-fog-lights/baja-designs/
Morimoto 4Bangers: https://www.4x4truckleds.com/led-auxiliary-lights/morimoto/4banger-led-pods/
What are 4Bangers you say? Well now, those are some hot new lights on the market. We're taking pre-orders on those (ETA for shipping is around mid December). We know you can fit 2 of them on our brackets (we did it on a Raptor), not 100% sure if 3 will fit (we've only got 1 pair that were sent to us early).
brianpgreen
Tacoma
2 door Badlands
You like the 4Bangers over the others?
Bigmoose
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
I'm not a fan of morimoto any more myself. I've had their stuff in previous vehicle headlight conversion kits (D2S). I had issues with their ballasts, bulbs, and even harness adapters. To be fair it's been 5 years or so since I bought from them.
I will say their warranty replacement was easy. Just cut wires and send a picture.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
So I knew I wanted to put some fogs in the modular bumper pocket. I liked the idea of both a white light and a yellow light so I could use either based on conditions. I also felt that all the "triple" kits looked way too crowded in the pocket. I also thought all the 2x2 pods (Squadron or SS3) looked too big for the space. Just my personal taste.
I settled on two 1x2 pods. Specifically the SSC2 Pros because I wanted good light in the 1x2 size along with an amber backlights. I really like the look of the SSC2s in this space @Diode Dynamics. I used the KR bracket with harness from @4x4TruckLEDs.com to mount and wire everything.
Here are my post install pics. I'll try to update this post at a later time with some night time pics.
Bench Top assembly:
Installed in the pocket:
Backlights: yes they actually look different IRL due to one having a yellow lens.
Whites ON:
Yellow ON:
Awesome job!
We're loving the dual SSC2 paired setup! 🙌
DC9atnight
Toyota Tacoma
Bench Top assembly:
Whites ON:
Yellow ON:
This setup looks great! Regarding the white SSC2s, did you go with SAE white fog?
21BRONCO
William
Los Angeles
best looking fogs yet. fitment looks perfect.
Bigmoose
Bigmoose
Jon
RI
4x4TruckLEDs.com
Adam
Lindenhurst, NY
For those looking to do a solution like this... we've got Diode Dynamics on sale right now, 15% off. Head over to our site at www.4x4TruckLEDs.com and check out the sales!
alexryer
Alex
Winchester, MA
2021 Bronco Black Diamond 4-Dr Soft Manual
Bench Top assembly:
Whites ON:
Yellow ON:
This is the best setup I've seen. I was thinking about a 6" light bar, but two 1x2's like you did looks better. It fills the space without crowding, and gives some flexibility. I'm following your lead!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
This is what you need then...
Bracket: https://www.4x4truckleds.com/kr-off-road-triple-fog-light-brackets-for-2021-ford-bronco/
Harness: Opt for the 3x SS3/SSC2 w/back-lit
Lights: Either SSC2 Sport (https://www.4x4truckleds.com/diode-dynamics/ssc2-sport/) or SSC2 Pro (https://www.4x4truckleds.com/diode-dynamics/ssc2-pro/)
smahones
Shane
Denver, CO
Ford Expedition
I
I agree, it looks great. Can you post some night pics when you have a chance? Thank you.
Bigmoose
Bigmoose
Jon
RI
Finally got some good night time pics. The biggest improvement is the wide throw of the light which is great for cornering.
Just headlights, low beams:
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211129_220741386
White pro fogs:
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211129_220747935
Yellow pro fogs:
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211129_220755761
imaginager
PDX / Oregon
Did you run the harness through over the top of the skid plate? Trying to stay clear of the front shutters.
Bigmoose
Bigmoose
Jon
RI
Yes I did! Forward of the two mounting points then used some zip ties. Easiest way to do it.
