Alignment after leveling kit question
Denis85
New York
2025 Bronco
So, my question is not so much SHOULD I (obviously ill need one), but more for those who have done leveling kits (specifically zone) did you have them realign it to factory specs or the specs they provided? From the look of it, the alignment specs Zone provide are not too far off from factory, but different enough to make me wonder. Just curious what everyone else on here is doing.
I went to a larger shop for mine. At first they tried to use the stock non-SAS values… which didn’t work for my 3” lift.
Made it home and called to take it back in. They re-did it to SAS values and has done pretty well there.
So… if Icon has a set they recommend, I would start there, then fall back to SAS if that doesnt track straight or the wheel’s cocked or they can’t get it in
Denis85
Denis85
New York
2025 Bronco
makes sense. I appreciate it.
