- First Name
- Ben
- Joined
- Jul 4, 2020
- Threads
- 18
- Messages
- 1,050
- Reaction score
- 2,067
- Location
- Southern California
- Vehicle(s)
- 2 Door Base Sasquatch
- Your Bronco Model
- Base
That is an awesome Bronco.
I would if I could keep the manual 7sp.Well after much thought I added the Sasquatch package to my 2 door black diamond build I just didn’t want to have regrets down the road. I got a better priority code too of 15 before I was 19. Salesman said that they are going to ramp up production in July and that I have the earliest time stamp at there dealer and should see movement soon. So we will see what happens
The width was the most noticeable difference between the 2Saw the 35" and 33" on the bronco and really couldn't tell the size difference. So you should be able to drop down in size and have the bronco look awesome
If you do the math you won’t be able to add the same stuff aftermarket for cheaper it’s really a good deal and covered under warrantyI am in the process of doing it too. I just sent my dealer a change request to add Squatch and remove the optional wheels. I like the optional wheels better, but I want the lower gear ratio for when I am not on pavement and it will save me from adding 35s later.
Just the gear change alone will offset the cost. I also won't have to buy 5 35s. Later I will purchase the 35s I really want once I wear the stock ones out. I'm glad to be back on the SquatchIf you do the math you won’t be able to add the same stuff aftermarket for cheaper it’s really a good deal and covered under Ed warranty
Your dealer is full of shit if you want Sasquatch get it you going to have regrets you didn’t get it from what I was told today the builds are going to start to ramp up in July it’s a crap shoot either way you look at it just get what you want cause if you decide to add sasqautch for 2022 you won’t be price protected if they raise the price of it and you didn’t already have it addedI asked my dealer a couple of weeks ago and he said the change could push my order to 2022. I have a day 2 reservation (12:30 AM), so I didn’t believe him, but decided to hold off. Any truth to the thought that it could push my order beyond just the potential SAS parts timing?
